Compare unrestricted and restricted VARX-DCC model
mengqi
I have bivariate VAR-DCC model with some exogenous variables in the conditional mean equations. How do I run a F-test, to see whether a restricted version of the model is preferable?
kind regards
kind regards
Re: Compare unrestricted and restricted VARX-DCC model
Probably the simplest thing would be to do a likelihood ratio test. To do a Wald test, use the Statistics--Regression Tests, pick Exclusion Restrictions and select the exogenous variables in the scrolling list.
Esteban
One doubt about what you answered. The thing is that the GARCH instruction doesn't define the variable %logdet (Log determinant), so what should we do in order to calculate the loglikelihood ratio?. By first calculating the determinant of the H matrices?. Or we just simply use the %logdet of the VAR as a good estimation of the average variance matrix Σ.
Thanks for your help.
Use %LOGL. %LOGDET only has a 1-1 mapping with the log likelihood for VAR's and similar models (with a covariance matrix fixed over time)---it's not defined by GARCH because it has no meaning with a GARCH model.
