* @RegHBreakCV( options )
* Regression post-processor which tests the regression just run for a
* full structural break with fixed regressor bootstrapping of the
* significance level. The test statistics are the Andrews-Quandt
* (maximum) and Andrews-Ploberger (geometric mean) of the F-statistics
* for the break.
* Options:
* REPS=# of residual bootstrap replications [100]
* PI1=fraction of early entries not examined as break points [.15]
* PI2=fraction of late entries not examined as break points [PI1]
* [PRINT]/NOPRINT
* PERCENTILES=||percentiles for lower and upper bounds|| [||.05,.10||]
* Variables Defined:
* %%BREAKPOINT Entry with largest break test
* %%AQTEST Andrews-Quandt test statistic
* %%APTEST Andrews-Ploberger test statistic
* %%AQSIGNIF Bootstrapped significance value for AQ test
* %%APSIGNIF Bootstrapped significance value for AP test
* %%AQL Bootstrapped Lower % critical value for AQ test
* %%AQU Bootstrapped Upper % critical value for AQ test
* %%APL Bootstrapped Lower % critical value for AP test
* %%APU Bootstrapped Upper % critical value for AP test
* References:
* Bruce Hansen(2000), "Testing for Structural Change in Conditional
* Models", Journal of Econometrics, vol. 97, no. 1, 93-115, July.
* Andrews and Ploberger(1994), "Optimal Tests When a Nuisance Parameter
* is Present Only Under the Alternative", Econometrica, vol 62, no 6,
* 1383-1414.
* Revision Schedule:
* 08/2010 Written by Tom Doan, Estima
* 05/2015 %%BREAKPOINT changed from REAL to INTEGER
* 03/2016 Added Critical Value Calculation
procedure RegHBreakCV depvar start end
type series depvar
type integer start end
option real pi1 .15
option real pi2 pi1
option integer reps 100
option switch print 1
option vector percentiles ||.05,.10||
local vect[int] reghold
local integer piStart piEnd rnobs rep time bestbreak
local series yb wstat u
local vect x
local symm dxx dxeex ss
local vect dxe
local real rssdiff fstat bestdiff apcount aqcount aqvalue apvalue ci
local string ltitle
local vect[real] aqteststorage apteststorage
decl real %%aqtest %%aptest %%aqsignif %%apsignif %%aql %%aqu %%apl %%apu
decl integer %%breakpoint
compute reghold=%regsave()
compute rnobs =%regend()-%regstart()+1
compute piStart=%regstart()+fix((rnobs-1)*pi1)
compute piEnd =%regstart()+fix((rnobs-1)*(1-pi2))
set u = %resids
dim dxx(%nreg,%nreg) dxeex(%nreg,%nreg) dxe(%nreg) aqteststorage(reps) apteststorage(reps)
compute percentiles(1) = 1.00-percentiles(1)
compute percentiles(2) = 1.00-percentiles(2)
compute bestdiff=0.0
compute apcount=aqcount=0.0
if reps>0
infobox(action=define,progress,lower=0,upper=reps) $
"Bootstrapping P-Values and Confidence Intervals"
do rep=0,reps
infobox(current=rep)
if rep==0
set yb = u
else
set yb = %ran(1.0)
* Run the regression on the residuals or bootstrapped residuals
linreg(lastreg,noprint) yb
compute dxx =%zeros(%nreg,%nreg)
compute dxeex=%zeros(%nreg,%nreg)
compute dxe =%zeros(%nreg,1)
set wstat piStart piEnd = 0.0
do time=%regstart(),%regend()
compute x=%eqnxvector(0,time)
compute dxx =dxx +%outerxx(x)
compute dxeex=dxeex+%outerxx(x*%resids(time))
compute dxe =dxe +x*%resids(time)
if time<piStart.or.time>piEnd
next
compute ss=(dxx-dxx*%xx*dxx)
compute rssdiff=%qform(inv(ss),dxe)
* This follows Hansen's example code. It's actually F/number of
* restrictions.
compute fstat=(rssdiff)/((%rss-rssdiff)/(%ndf-%nreg))
compute wstat(time)=fstat
if rep==0.and.rssdiff>bestdiff
compute bestbreak=time,bestdiff=rssdiff
end do time
* Compute sup F and overflow-safe exp F statistic
sstats(max) piStart piEnd wstat>>aqvalue
sstats(mean) piStart piEnd exp(.5*(wstat-aqvalue))>>apvalue
compute apvalue=log(apvalue)+.5*aqvalue
* Save the test statistics for rep==0; count the number above the
* saved statistics for the bootstrapped data.
if rep==0
compute %%aqtest=aqvalue,%%aptest=apvalue
else
compute aqcount=aqcount+(aqvalue>%%aqtest),apcount=apcount+(apvalue>%%aptest),aqteststorage(rep)=aqvalue,apteststorage(rep)=apvalue
end do rep
infobox(action=remove)
compute %%apsignif=%if(reps>0,apcount/reps,%na)
compute %%aqsignif=%if(reps>0,aqcount/reps,%na)
compute %%breakpoint=bestbreak
compute fracaq=%fractiles(aqteststorage,percentiles)
compute fracap=%fractiles(apteststorage,percentiles)
compute %%aql=fracaq(1)
compute %%aqu=fracaq(2)
compute %%apl=fracap(1)
compute %%apu=fracap(2)
compute ltitle="AQ-AP Break Tests/Bootstrapped P-Values and Critical Values"
report(use=hreport,action=define,title=ltitle)
report(use=hreport,atrow=1,atcol=1,span) ltitle
report(use=hreport,atrow=2,atcol=1) "Estimated Break" %datelabel(bestbreak)
report(use=hreport,atrow=3,atcol=2) "Statistic" "Signif" 1-percentiles(2) "Crit Val" 1-percentiles(1) "Crit Val"
report(use=hreport,atrow=4,atcol=1) "Andrews-Quandt Test" %%aqtest %%aqsignif %%aqu %%aql
report(use=hreport,atrow=5,atcol=1) "Andrews-Ploberger Test" %%aptest %%apsignif %%apu %%apl
report(use=hreport,atrow=3,torow=3,action=format,picture="#.####")
report(use=hreport,atcol=2,tocol=2,action=format,picture="#.###")
report(use=hreport,atcol=3,tocol=3,action=format,picture="#.#####")
if print
report(use=hreport,action=show)
compute %regload(reghold)
end HBreakTest
extremum(noprint) rss(i) piStart piEnd
comp brkdates(i) = %minent
extremum(noprint) wstat(i) piStart piEnd
comp brkdates(i) = %maxent
alvarezcc wrote:Hi Tom! Is it possible for you to change the code for performing the AP-test in order to also show (or replace) the mean of the LM statistic by the exponential statistic?
set wstat(i) piStart piEnd = 0.0
set rss(i) piStart piEnd = 0.0
set wstat(i) piStart piEnd = %na
set rss(i) piStart piEnd = %na
