Gibbs Var with Minnesota Prior and Exogenous Variables
Re: Gibbs Var with Minnesota Prior and Exogenous Variables
Sure. Inverse wishart prior is natural for that model. However, while possible, it's not clear why you would do that---unless you have a very short data set, the covariance matrix is reasonably well estimated without the need for a prior.
