Hansen's bootstrap to compute critical value of F-distributi
Hshadmani
Unread post by Hshadmani »
Hello!
I am running an endogenous Threshold Regression using a grid search to find the best breakvalue. Now I want to compare this model to OLS through F-statistics. I know I should use Hansen's bootstrap method rather than the standard F-distribution table to compute critical value. I was wondering if there is any way to find the critical value in Rats using Hansen's bootstrap.
Hedieh
Re: Hansen's bootstrap to compute critical value of F-distri
That's exactly what @THRESHTEST does.
Hshadmani
So the critical value is the Maximum F-test in the output?
Yes.
Hshadmani
Thank you!
