Dear Tom/ Community,
following my question regarding Minnesota Near VAR Gibbs, I have written some code, which I would like to share to the community. However, sofar I am not entirely sure, whether I coded up everything correctly. The data form Cushman & Zha (1997) are aused, to assure that everybody can use the code.
* Read in Data *
cal(m) 1974:1
all 1993:12
open data dc11cit.asc
data(format=free,org=columns) / exc m1boc tbill cpi ip $
expo imphs ipus cpius ffrus wxcp
************ General Setup ************
compute lags=2 ;*Number of lags
compute nstep=50 ;*Number of response steps
compute ndraws=5000 ;*Number of keeper draws
compute nburn=4000 ;*Number of burn-in draws
compute keep = ndraws - nburn ;*Number of kept draws
compute nvari = 11 ;*Number of coefficients in endogenous equation
compute ncoef = nvari*lags+1 ;*Number of coefficients per equation, +1 for intercept
compute nexo = 4 ;*Number of variables in exogenous block
compute tight= 0.2
compute other= 0.5
*** Model Setup ***
system(model=varexo)
variables ipus cpius ffrus wxcp
lags 1 to lags
system(model=varend)
variables exc m1boc tbill cpi ip expo imphs
lags 1 to lags
det ipus{1 to lags} cpius{1 to lags} ffrus{1 to lags} wxcp{1 to lags} constant
compute fullmodel = varexo + varend ;* Creates the Near VAR, such that the exogenous Block is ordered last
@SURGibbsSetup fullmodel
sur(noprint,nosigma,model=fullmodel,cv=%identity(neqn),cmom)
compute bdraw=%vec(%modelgetcoeffs(fullmodel)) ;*for initial draw of VAR coefficients, use vector of stacked slope coefficeints from OLS
compute nvar=%nvar
*** Set up SDs from AR(1) Models for Scaling ***
declare vect olsseen(nvar) ;* vector of standard errors from AR(1), endogenous variables
compute i = 1
dofor x = exc m1boc tbill cpi ip expo imphs ipus cpius ffrus wxcp
linreg(noprint) x
# constant x{1}
compute olsseen(i)=sqrt(%SEESQ)
compite i=i+1
end do
declare vect olsseex(nexo) ;* vector of standard errors from AR(1), exogenous variables
compute i = 1
dofor x = ipus cpius ffrus wxcp
linreg(noprint) x
# constant x{1}
compute olsseex(i)=sqrt(%SEESQ)
compite i=i+1
end dofor
*** Set up some Storgae Space ***
declare vect[rect] %%responses(keep) ;* Storage Vector of Rectanculars for Impulse Response Draws
******** Minnesota Prior for VAR Coefficients Exogenous before Endogenous *********
dec rect minnmean(ncoef,nvar) minnprec(ncoef,nvar)
compute minnmean = %zeros(ncoef,nvar)
compute minnprec = %zeros(ncoef,nvar)
** first do the part for the exogenous block:
do i=1,nexo
do j=1,nexo
do l=1,lags
compute minnmean((j-1)*lags+l,i)=%if(i==j.and.l==1,1,0) ;* sets first on log to 1 and everything else to zero
compute minnprec((j-1)*lags+l,i)=(olsseex(j)/olsseex(i))*%if(i==j,l/tight,l/(other*tight)) ;* computes the corresponding minnesota precisions
end do l
compute minnmean(ncoef-(nvar-nexo)*lags,i)=0.0,minnprec(ncoef-(nvar-nexo)*lags,i)=100*olsseex(i) ;* sets the mean and precision for the intercept
** second do the part for the endogenous block:
do i=nexo+1,nvar
do j=1, nvar
do l=1,lags
compute minnmean((j-1)*lags+l,i)=%if(i-nexo==j.and.l==1,1,0) ;* sets first on log to 1 and everything else to zero
compute minnprec((j-1)*lags+l,i)=(olsseen(j)/olsseen(i-nexo))*%if(i-nexo==j,l/tight,l/(other*tight)) ;* computes the corresponding minnesota precisions
end do l
compute minnmean(ncoef,i)=0.0,minnprec(ncoef,i)=100*olsseen(i-nexo) ;* sets the mean and precision for the intercept
ewise minnprec(i,j)=minnprec(i,j)^2
*** compress the precision and slope prior to get all rows out that are zero in the exogenous equations
*** to have matching dimensions in the sampler
declare vect help
compute help = %ones(%rows(%vec(minnprec)),1)
do i=1,%rows(%vec(minnprec))
compute help(i)=%if(%vec(minnprec)(i)==0,0,1)
compute vecminnprec = %compress(%vec(minnprec),help)
compute vecminnmean = %compress(%vec(minnmean),help)
compute hprior=%diag(vecminnprec)
compute bprior=vecminnmean
********* Flat Prior for Precision *********
compute hxxprior=%zeros(neqn,neqn)
compute nuprior =0.0
compute wishdof=nuprior+%nobs
********* Gibbs Sampler *********
infobox(action=define,progress,lower=1,upper=ndraws) "Gibbs Sampler"
do draw= 1,ndraws
infobox(current=draw)
*** Draw Precision given b ***
compute covmat=SURGibbsSigma(bdraw)+hxxprior
compute hdraw=%ranwishartf(%decomp(inv(covmat)),wishdof)
*** Draw b given sigma ***
@SURGibbsDataInfo hdraw hdata hbdata
compute hpost=hdata+hprior
compute vpost=inv(hpost)
compute bpost=vpost*(hbdata+hprior*bprior)
compute bdraw=bpost+%ranmvnormal(%decomp(vpost))
if draw<=nburn
next
*** Set Modelcoefficients and draw IRFs ***
compute %modelsetcoeffs(fullmodel,bdraw)
compute fact=%decomp(inv(hdraw))
impulse(noprint,model=fullmodel,results=impulses,steps=nstep,flatten=%%responses(draw-nburn),factor=fact)
end do draw
infobox(action=remove)
display %modelgetcoeffs(fullmodel)
@mcgraphirf(model=fullmodel,center=median,percent=||0.16,0.84||,page=byshock)
The VAR is estimated like a SUR.
I still have some questions:
1) When I type in "display %modelgetcoeffs(fullmodel)" I get for the endogenous block variables zeros in the equations of the exogenous block variables
1.24072 0.01385 1.03698 0.07823 1.07464 0.04782 -2.33703 -0.00781 0.01577 -0.19422 -0.26280
-0.26147 5.96474e-04 -2.41643 -0.00302 -0.06803 -0.05613 2.81767 -0.00106 -0.08700 0.14589 0.21388
0.18931 1.09332 -9.90841 -0.18247 0.00143 0.80422 3.07745 0.01217 -0.00117 -0.06534 -0.13205
-0.18502 -0.10546 10.01533 0.16083 0.00130 0.13264 -2.12586 -7.84323e-04 0.06404 0.10133 0.29192
-6.96298e-05 1.49607e-04 1.15070 -0.00105 4.42312e-04 -0.00292 0.89651 1.27891e-04 4.43314e-04 -0.00162 -0.00274
-9.91628e-04 1.69525e-04 -0.21637 0.00140 8.29788e-04 0.00133 -0.03677 9.52162e-05 -6.71114e-05 -4.81388e-04 -9.17110e-04
0.03445 0.00966 2.89109 1.28742 0.04626 0.20593 15.32523 0.97133 -0.35942 -0.43150 -0.27949
-0.02232 -0.00565 -1.52980 -0.32648 -0.00696 -0.23940 -10.83981 -0.01041 0.27840 0.30974 0.00366
0.02778 -0.02847 0.01266 -0.06521 0.09301 0.03806 1.75577 -0.00147 0.78453 0.10840 0.13670
0.00000 0.00000 0.00000 0.00000 -0.04352 -0.02862 0.21689 0.00462 0.11134 -0.15316 -0.01881
0.00000 0.00000 0.00000 0.00000 -0.00779 -0.06572 1.35918 -6.51365e-04 -0.03249 1.00747 0.05918
0.00000 0.00000 0.00000 0.00000 -0.00496 0.01350 -1.20777 -0.00422 0.03785 -0.03495 0.07508
0.00000 0.00000 0.00000 0.00000 0.00192 0.01889 -0.82737 -0.00994 -0.03206 -0.08473 0.82165
0.00000 0.00000 0.00000 0.00000 0.02726 0.03348 0.20086 0.00839 0.00531 0.03009 -0.05235
0.00000 0.00000 0.00000 0.00000 0.07587 0.01371 2.87824 0.00978 0.04221 0.22686 -0.19240
0.00000 0.00000 0.00000 0.00000 -0.11411 -0.01811 -6.69188 -0.00928 0.05279 -0.11289 0.10268
0.00000 0.00000 0.00000 0.00000 0.06977 0.10793 0.13234 0.00544 -0.35410 0.03554 -0.31752
0.00000 0.00000 0.00000 0.00000 -0.11342 0.00102 -4.99108 0.02147 0.35215 0.04720 0.44730
0.00000 0.00000 0.00000 0.00000 -0.00141 -8.32498e-04 0.09103 3.35145e-04 -0.00174 5.13385e-05 0.00302
0.00000 0.00000 0.00000 0.00000 6.17902e-04 -3.83159e-05 0.00884 -1.27061e-04 1.99758e-04 3.77815e-04 -3.99306e-05
0.00000 0.00000 0.00000 0.00000 -0.00424 0.01610 2.17363 -0.00498 0.01776 0.03983 9.95922e-05
0.00000 0.00000 0.00000 0.00000 -0.00451 -0.02452 -0.89379 0.00761 0.01028 -0.00632 0.04543
0.00000 0.00000 0.00000 0.00000 -0.31445 0.41087 -0.00586 0.04696 0.28936 0.86634 0.35873
However I need to get rid of all those enties which are zero within the Gibbs sampler, because otherwise "hdata+hprior" have different dimensions. I did this by vectorizing the meanprecision and set up a help variable, which takes values of zero whenever the the vectorized meanprec is equal to zero. Then I used "%compress(%vec(minnprec),help)" and "%compress(%vec(minnmean),help)" to take all the zero elements out such that the dimensions for "hdata" and "hprior" match.
Is this the correct way of getting the Minnesota prior for the near VAR?
2) I checked it 100 times, but its good to have some cross-check. Are precision parameter assingned to the right slots?
do i=1,nexo
do j=1,nexo
do l=1,lags
end do l
do i=nexo+1,nvar
do j=1, nvar
do l=1,lags
end do l
3) The code slows down extreamly when I increase the number of lags, do you see some inefficiency, which can be altered such that the code gets a bit faster?
Thank you in advance
Best
Jules
