Multivariate ANST-GARCH
huanpipt
Post by huanpipt »
Hello, I want to run a bivariate ANST-GARCH-M.
I have some problem in following part,
set rs = uu(t)(1,1)
set rf = uu(t)(2,2)
set fs = (1+%exp(-L*rs{1}))^(-1)
set ff = (1+%exp(-L*rf{1}))^(-1)
gset F = ||fs,ff||
There is a error message
"## SX22. Expected Type REAL, Got MATRIX(REAL) Instead
>>>>xp(-L*rs{1}))^(-1)<<<<"
But I don't know how to revise these part.
Following is whole code.
compute n=2
compute gstart=1,gend=1555
dec series[vect] Y
dec frml[vect] R
dec vect[series] U(n)
dec series[vect] ECT
* SERIES[SYMM] named H and UU. UX and HX are used for the current values
* of the residual vector and H matrices
declare series[symm] G uu
declare symm Gx(n,n)
declare vect ux(n)
* These will be the parameters for the mean equations. These are adjusted to add
* variance or covariance terms as needed.
dec vect F(n)
dec vect EC(n) C1(n) C2(n)
dec rect T1(n,n) T2(n,n) F1(n,n) F2(n,n)
nonlin(parmset=meanparms) EC C1 C2 T1 T2 F1 F2 L
* Mean model = VAR(1) with sqrt(G) "M" term
frml R = Y-EC.*ECT{1}-C1-C2.*F-T1*Y{1}-T2.*F*Y{1}-F1*%sqrt(%xdiag(G))-F2.*F*%sqrt(%xdiag(G))
gset Y = ||dLSP,dLF1M||
linreg LSP / ECTEQ
# LF1M
gset ECT = ||ECTEQ,ECTEQ||
* Run preliminary VAR(4) to get estimates of residuals
linreg dLSP / u(1)
# constant dLSP{1} dLF1M{1} ecteq{1}
linreg dLF1M / u(2)
linreg dLSP
# constant dLSP{1} DLF1M{1} u(1) u(2) ecteq{1}
compute C1(1)=%beta(1),C2(1)=%beta(1),$
        T1(1,1)=%beta(2),T2(1,1)=%beta(2),$
        T1(1,2)=%beta(3),T2(1,2)=%beta(3),$
        F1(1,1)=%beta(4),F2(1,1)=%beta(4),$
        F1(1,2)=%beta(5),F2(1,2)=%beta(5),$
        EC(1)=%beta(6)
linreg dLF1M
# constant dLSP{1} dLF1M{1} u(1) u(2) ecteq{1}
compute C1(2)=%beta(1),C2(2)=%beta(1),$
        T1(2,1)=%beta(2),T2(2,1)=%beta(2),$
        T1(2,2)=%beta(3),T2(2,2)=%beta(3),$
        F1(2,1)=%beta(4),F2(2,1)=%beta(4),$
        F1(2,2)=%beta(5),F2(2,2)=%beta(5),$
        EC(2)=%beta(6)
vcv(matrix=WWW)
# u
gset G  * gend = WWW
gset uu * gend = WWW
set u(1) = 0.0
set u(2) = 0.0
declare frml[symm] Gf
frml logl = $
    Gx    = Gf(t) , $
    G(t)  = Gx, $
    ux    = R , $
    uu(t) = %outerxx(ux), $
    %pt(u,t,ux),$
    %logdensity(Gx,ux)
set rs = uu(t)(1,1)
set rf = uu(t)(2,2)
gset F = ||fs,ff||
Re: Multivariate ANST-GARCH
set rs = uu(t)(1,1)
set rf = uu(t)(2,2)
gset F = ||fs,ff||
You have two problems with this. First, you want to use just exp, not %exp in the third and fourth instructions. That's what's giving you the syntax error. However, you have a more fundamental problem. FS and FF depend upon L, which is one of your free parameters. A SET instruction will evaluate those only at the current value of L, so FS and FF won't change when L is updated as part of your estimation (and as a result, neither will F, which uses FS and FF). Instead, I think you want the following:
frml fs = (1+exp(-L*rs{1}))^(-1)
frml ff = (1+exp(-L*rf{1}))^(-1)
dec frml[vect] f
frml F = ||fs,ff||[/code]
huanpipt
Post by huanpipt »
Thanks your response.
But there is another problem.
I revised the code as following,
set rs = uu(t)(1,1)
set rf = uu(t)(2,2)
dec frml[vect] F
frml F = ||fs,ff||
A error message comes
"## MAT15. Subscripts Too Large or Non-Positive
Error was evaluating entry 1"
I have found the error part,
set rs = uu(t)(1,1)
set rf = uu(t)(2,2)
After I added following code, the problem has not been solved.
dec series rs
dec series rf
This is my whole code, and I attach the data in this post.
compute n=2
dec series[vect] Y
dec frml[vect] R
dec series rs
dec series rf
declare vect ux(n)
dec frml[vect] F
set rs = uu(t)(1,1)
set rf = uu(t)(2,2)
frml F = ||fs,ff||
linreg LSP / ECTEQ
# LF1M
linreg dLSP / u(1)
linreg dLF1M / u(2)
linreg dLSP
        EC(1)=%beta(6)
linreg dLF1M
        EC(2)=%beta(6)
compute L = 30
vcv(matrix=WWW)
# u
gset G  * gend = WWW
set u(1) = 0.0
set u(2) = 0.0
frml logl = $
    Gx    = Gf(t) , $
    G(t)  = Gx, $
    ux    = R , $
    %pt(u,t,ux),$
    %logdensity(Gx,ux)
* This does a simple GARCH(1,1) model for the variance.
dec symm A1(n,n) A2(n,n) A3(n,n) B1(n,n) B2(n,n) B3(n,n)
compute A1=WWW,B1=WWW,A2=%const(0.50),B2=%const(0.50),A3=%const(0.05),B3=%const(0.05)
nonlin(parmset=garchparms) A1 A2 A3 B1 B2 B3
frml Gf = A1+A2.*G{1}+A3.*uu{1}+(B1+B2.*G{1}+B3.*uu{1})*F
maximize(trace,parmset=meanparms+garchparms,pmethod=bfgs,piters=100,method=bfgs,iters=200) logl gstart+2 gend
* This does a BEKK model for the variance
dec rect AA2(n,n) AA3(n,n) BB2(n,n) BB3(n,n)
compute AA2=.05*%identity(n),AA3=.50*%identity(n),BB2=.05*%identity(n),BB3=.50*%identity(n)
compute A1=%decomp(WWW),B1=%decomp(WWW)
nonlin(parmset=garchparms) A1 AA2 AA3 B1 BB2 BB3
frml Gf = A1*tr(A1)+AA3*G{1}*tr(AA3)+AA2*uu{1}*tr(AA2)+(B1*tr(B1)+BB3*G{1}*tr(BB3)+BB2*uu{1}*tr(BB2))*F
TD3insample.xls
(229 KiB) Downloaded 926 times
Do those SET instructions only over the range for which UU would be actually be defined.
huanpipt
Post by huanpipt »
I've adjusted my code,
set rs gstart+2 gend = uu(t)(1,1)
set rf gstart+2 gend = uu(t)(2,2)
frml fs = 1/(1+exp(-L*rs{1}))
frml ff = 1/(1+exp(-L*rf{1}))
frml F = ||fs,ff||
, but it doesn't work with the same error message.
and I try to run the following code,
set rs = u(1)
set rf = u(2)
frml F = ||fs,ff||
, it work, but the usable sample is not as I expected.
The much sample is skipped, and every time I run the same code with different usable data which is shown from the result table.
I want to know if the code is wrong to deal with the multivariate smooth transformation function, and how to correct it right.
Thanks for your help.
Hoping hear from your, I am.
Aren't your dimensions wrong on F? It should be a 2 x 2 matrix, not a 2 vector.
huanpipt
Post by huanpipt »
It really help me a lot.
I forget the F in the mean equation should not be the same as in the variance equation.
I have create a new 2*2 matrix, V, for the variance equation.
It work with correct sample, only the result is not perfect perhaps due to the wrong initial setting.
Following is my added code, would you mind to see if there is still problem.
And I appreciate your helping very much. :)
dec frml[vect] F
dec frml[symm] V
frml rs = uu(t)(1,1)**(1/2)
frml rf = uu(t)(2,2)**(1/2)
frml rsf = uu(t)(1,2)**(1/2)
frml fsf = 1/(1+exp(-L*rsf{1}))
frml F = ||fs,ff||
frml V = ||fs|fsf,ff||
At this point, it would probably make the most sense for you to e-mail the set of equations that you're trying to estimate to us at support@estima.com.
wendystanner
Post by wendystanner »
Hi there. The multivatiate code is awesome,however, it does not work well for my data due to convergence problem. Is there a univariate version of ANST-GARCH available? I want to run two uni- model and then calculate hedge ratio. Thanks a lot.
See https://estima.com/forum/viewtopic.php? ... 123#p15750. However, how would you compute the hedge ratio from two separate univariate models? That wouldn't estimate the covariance, just the two variances.
