Fry-Pagan JEL 2011
Fry-Pagan JEL 2011
This is an example of the calculation of Fry-Pagan (2011) median target estimators. "Sign Restrictions in Structural Vector Autoregressions: A Critical Review," Journal of Economic Literature, vol. 49, no. 4, 938-60. The example is taken from Uhlig(2005), "What are the effects of monetary policy on output? Results from an agnostic identification procedure", Journal of Monetary Economics, 52, pp 381-419.
As noted in the comments, there is no reason that the minimum distance response has to be inside the [16-84]-ile bands at every point, and in this case, the short-run responses for non-borrowed reserves are outside of it.
Re: Fry-Pagan JEL 2011
Hi Tom, I tried implementing the Fry-Pagan minimization in a different setting. You did mention that the selected impulse might lie outside the confidence bands. On a more fundamental note, will the Fry-Pagan approach guarantee that the selected impulse satisfies the sign restrictions we impose (in all the horizons)? I suspect the minimization routine does not guarantee that, but would like to double check with you.
That's correct. It chooses the impulse vector whose responses come "closest" to the median of the cloud of responses which do satisfy the constraints, but there is no guarantee that it itself satisfies those constraints.luching wrote:Hi Tom, I tried implementing the Fry-Pagan minimization in a different setting. You did mention that the selected impulse might lie outside the confidence bands. On a more fundamental note, will the Fry-Pagan approach guarantee that the selected impulse satisfies the sign restrictions we impose (in all the horizons)? I suspect the minimization routine does not guarantee that, but would like to double check with you.
Tom,
How might I alter this code to produce forecast error variance decomposition?
I tried altering it with aspects of the Uhlig (2005) code, but had no success.
Add this to the end. It's just a single shock, so it's just a single calculation.
* Compute the percentages of this shock in the FEVD
declare vector ones ik
declare rect fevd(nstep,nvar)
compute ones=%fill(nvar,1,1.0)
gset irfsquared 1 1 = %xt(impulses,t).^2
ewise fevd(i,j)=ik=(irfsquared(i)*(a.^2))./(irfsquared(i)*ones),ik(j)
report(action=define,title="Forecast Variance Explained by FP Shock")
report(atrow=1,atcol=2,align=center) vl
report(atcol=1,atrow=2,fillby=cols) %seq(1,nstep)
report(atrow=2,atcol=2) 100.0*fevd
report(action=format,atrow=2,picture="###.###")
report(action=show)Re: Fry-Pagan JEL 2011
Thanks. How might I graph the FEVDs? I've tried the following, but no success.
do i=1,nvar
compute minlower=maxupper=0.0
smpl 1 accept
do k=1,nstep
set work = fevd(t)(k,i)
compute frac=%fractiles(work,||.16,.50,.84||)
compute lower(k)=frac(1)
compute upper(k)=frac(3)
compute resp(k)=frac(2)
end do k
do i=1,nvar
smpl 1 accept
do k=1,nstep
end do k
Graph what? It's one shock.
Can I not graph the FEVD for the 1, 2, 3, ....step ahead? So for GDP, can I simple create a graph of the numbers that coincide with the FEVD.
I guess what I'm saying is, instead of presenting the numbers, is there a better graphical presentation?
It's one shock. There are no error bands. I'm not sure what a graph is doing that's not obvious from the table. (To be perfectly honest, I don't even know what an FEVD of the FP shock is supposed to be showing anyway).
Is it possible to calculate the error variance for each accepted draw, and then use that info to construct an error variance graph from 1 to 50 steps ahead?
The original Uhlig paper has FEVD's done what way. You're posting questions in a thread about Fry-Pagan.
