Rolling Covariance
Jules89
Rolling Covariance
Unread post by Jules89 »
I have a very simple prolem. When I have two series x and y, how can I calculate a rolling covariance between the two.
For example I want to calculate cov(x(t),y(t)) for t=1,...,20. Then I want to calculate cov(x(t),y(t)) for t=2,...,21 and so on. Then I want to save the covariance for later calculation within each iteration of the loop.
The cross instruction works well for printing the values, but I don't know how to safe the values. My code is
start = some date
end = some date +20
do i = 0, 1813
   cross(from=0, to=0,covariances,results=cov) x y start+i end+i
Thank you
best jules
Re: Rolling Covariance
That's a rather short window, isn't it?
At any rate, the bookkeeping for rolling window analyses is largely the same regardless of what you're computing. See rollingcausality.rpf and the handling of causetests series. In your case, the statistic that you want to save on each trip through is cov(1).
Jules89
Thanks Tom,
cov(1) was the command I was serching for.
Best Jules
