Real Time Business Cycle Dating with DFMS
danon
Unread post by danon »
Hi dear Mr Tom, I am working on Markov-switching Dynamic factor model.
I would like to know if you have a detailed examples for REAL TIME marov switching like in the attached paper (Codes are available but in GAUSS).
Need to buy that one if it exists.
Best regards
Danon
Real Time BusinessCycle.pdf
(333.46 KiB) Downloaded 855 times
Re: Real Time Business Cycle Dating with DFMS
Am I missing something, or is this a 2012 working paper that's never been published?
The Kim filter is covered in detail in the Structural Breaks and Switching Models e-course. Aruoba-Diebold-Scotti uses mixed frequency data. It looks like what they're doing is a combination of the two of those. However, I would be somewhat skeptical about how well this actually would work---the Kim filter has accuracy problems to start (for computing an approximate log likelihood), and using it with a state-space model as vague as a factor model seems like a bad idea.
danon
I do understand, i am better use the GAUSS code available!?
Best regards
Danon
If you want to pursue that, yes. I just think you'll find that it's not worth the effort.
