one common legend in SPGRAPH
sleu123
Unread post by sleu123 »
I am plotting FEVD stacked graphs for 3 different countries. Each country is decomposed by five factors. I am wondering whether it is possible to have one common legend showing the colour scheme of the five factors at the bottom of the SPGRAPH? If not with SPGRAPH, what might be another way of doing so in RATS?
spgraph(vfields=2,hfields=2)
graph(header='Australia',number=0,style=stacked,min=0,max=100,scale=both) 5
# AUS_FEVD_RG; # AUS_FEVD_US; # AUS_FEVD_EU; # AUS_FEVD_JP; # AUS_FEVD_CN
graph(header='Hong Kong',number=0,style=stacked,min=0,max=100,scale=both) 5
# HK_FEVD_RG; # HK_FEVD_US; # HK_FEVD_EU; # HK_FEVD_JP; # HK_FEVD_CN
graph(header='New Zealand',number=0,style=stacked,min=0,max=100,scale=both) 5
# NZ_FEVD_RG; # NZ_FEVD_US; # NZ_FEVD_EU; # NZ_FEVD_JP; # NZ_FEVD_CN
Thanks for your time in advance.
Shawn
Re: one common legend in SPGRAPH
The common legend has been added with version 9. To the outer SPGRAPH, you would add the options
STYLE=STACKED,KEY=BELOW,KLABELS=||"RG","US","EU","JP","CN"|| (or whatever you want for the labels).
Anne
Unread post by Anne »
Hi Tom
Is it possible to use a common legend with spgraph that can control the colors associated with series. When I try to implement this I can only seem to get the first 2 colors black and blue if I am plotting 2 series rather than the colors I have selected using the graph option i.e. the key colors don’t correspond to the actual colors plotted in the graphs
Use the SYMBOLS option to remap the symbol styles.
Anne
Thanks Tom
Worked Perfectly
