store the results in the loop
sam
I am simulating 20000 results for VIRF (with three series system). I successfully simulate the 20,000 random shocks from t distribution, but when I tried to get the simulated VIRF, instead of getting 20,000 unique VIRFs for each variance and covariance, I received 2580 VIRFs with the same value for each variance and covariance.
I tried to modify the code many times, and still cannot get it right. I think I should create a storage variable, but I don't know if it is the right thing to do. Can you help me to look at the code below? Am I missing something?
Thank you so much!
FYI,
I am studying 3 series.
The number of observation for each series is 2580.
hvec0 is a 6 by 1vector,
%%vech_a, %%vech_b are 6 by 6 matrix.
The value of shock0 is the value for the 20,000th simulated shock
Yours,
Sam.
set randshock 1 20000 = %rant(3.14)
compute nstep=1
do j = 1,20000
compute shock0 = %fill(6,1,1)*randshock(j)
do step=1,2
if step==1
compute hvec0=%%vech_a*shock0
else
compute hvec0=(%%vech_a+%%vech_b+%%vech_d)*hvec0
end do step
Set ban081 = hvec0(1,1)
Set ban082 = hvec0(2,1)
Set ban083 = hvec0(3,1)
Set ban084 = hvec0(4,1)
Set ban085 = hvec0(5,1)
Set ban086 = hvec0(6,1)
Thank you so much!
FYI,
Yours,
Sam.
compute nstep=1
do j = 1,20000
do step=1,2
if step==1
else
end do step
Re: store the results in the loop
I assume the intention is to save a separate value for each draw into ban081,...,ban086.
outside the loop:
clear(length=20000) ban081 ban082 ban083 ban084 ban085 ban086
inside the loop
compute ban081(j)=hvec0(1,1)
compute ban082(j)=hveco(2,1)
etc.
The incorrect
set ban081 = hvec0(1,1)
sets all elements of ban081 to the one value (which is what you were seeing).
outside the loop:
inside the loop
etc.
The incorrect
sam
Thank you so much for your help, which saved my life! THANK YOU! I got the results now.
I have an extended question. "clear (length=)" will give me a "container" for storing the simulation results as a series.
However, if I want to store the results as a matrix, which command will allow me to create the "container" for a matrix?
Thank you so much!
Yours,
Sam.
Thank you so much!
Yours,
Sam.
outside the loop
dec rect ban08(20000,6)
inside the loop
compute ban08(j,1)=hvec0(1,1)
compute ban08(j,2)=hvec0(2,1)
etc.
Note, it's a good idea to put the 20000 into a variable (like NDRAWS) and write everything else in terms of NDRAWS so you can change it just once.
inside the loop
etc.
sam
Thank you so so much, Tom!!!! Happy holidays!
Yours,
Sam.
Yours,
Sam.
