VARLAGSELECT—Automatic lag selection in a VAR
Re: VARLAGSELECT—Automatic lag selection in a VAR
Hello Tom, Can I use @varlagselect on VARX model?
No. But the VARLAG.RPF program shows how the calculations are done within @VARLAGSELECT and you can adjust the VAR within that to include the "X" variables.zw83189 wrote:Hello Tom, Can I use @varlagselect on VARX model?
Thanks Tom.
Thanks for your reply. Do I just need to change the endogenous variables/data period and include the exogenous variables in deterministic option, and keep the rest the same?
For the deterministic option, I put " det constant lhashbtc dlb dtb*lhashbtc ". Where lhashbtc is my exogenous variable and dlb is the intercept dummy, dtb is the trend dummy.
I tried the following code but an error message showed up.
## SR3. Tried to Use Series Number 195, Only 19 Are Available
system(model=varmodel)
variables logrbtc logrltc
lags 1
det constant volbtc volltc tranbtc tranltc lwikibtc lwikiltc lhashbtc lhashltc dll dtb*lhashbtc
report(action=define,hlabel=||"Lags","AIC","SBC","LR Test","P-Value"||)
dec real lastll
do lags=1,8
lags 1 to lags
det constant lhashbtc lhashltc dlb dtb*lhashbtc
estimate
compute ll =%logl
compute sbc=-2.0*ll/%nobs+%nregsystem*log(%nobs)/%nobs
compute aic=-2.0*ll/%nobs+%nregsystem*2.0*%nvar/(%nvar*%nobs-%nregsystem-1)
report(row=new,atcol=1,align=decimal) lags aic sbc
if lags>1
report(row=current,atcol=4) 2*(ll-lastll) %chisqr(2*(ll-lastll),%nvar*%nvar)
compute lastll=ll
end do lags
report(action=format,atcol=2,tocol=2,special=onestar,tag=min,align=decimal)
report(action=format,atcol=3,tocol=3,special=onestar,tag=min,align=decimal)
report(action=format,atcol=2,tocol=3,width=8)
report(action=format,atcol=4,tocol=5,picture="*.####")
report(action=show)
You can't use dtb*lhashbtc in a regressor list. Do a separate SET instruction for the interaction, that is, something like
set combo = dtb*lhashbtc
and then
det constant lhashbtc lhashltc dlb combo
and then
@varlagselect(crit=AIC,signif=0.05,lags=12) 2003:07 2018:09
# DiffX1 DiffX2 DiffX3 logX4 X5
So in the model i am trying to run there is one cointegrating vector, furthermore the sample starts from 2002:06 and for ADF tests I had to difference the variables once. So my question is that given the command above, the procedure will run the models and minimize the criteria using an estimation period from 2003:07 to 2018:09 and will pick lags 1 through 12 starting from 2002:07 to 2003:06?
Right?
Ateeb Syed
Right?
Ateeb Syed
The SIGNIF option doesn't matter because the CRIT=AIC controls. If you're trying to use the full sample at the start, simply use * 2018:9 as the range. (Or if you want to use the maximum possible data, just skip the range entirely). As written it will use entries from 2003:7 to 2018:9, which means data to give 12 lags from 2002:8 on.
Note that if the series are cointegrated, you should pick the lags on the levels, not the differences. And while it won't happen with levels on cointegrated series (or any I(1) series), the number of lags will be chosen from 0 to 12, not 1 to 120.
Thank you,
it means i should use
@varlagselect(Crit=AIC,lags=12) 2003:07 2018:09
# Logdebt LogCPI LogM1 LogLSM R
Actually Logdebt, LogCPI and LogM1 are cointegrated and LogLSM and R are stationary in levels. so am i doing it right? my original sample is 2002:06 to 2018:09. so it will pick 12 lags starting from 2002:07 right? you stated 2002:08 in last comment but does'nt that mean 2002:08 to 2003:06 11 lags because i want my estimation period to be same for all estimations?
Thanks for responding quickly.
All the VAR estimates use the same set of entries (the AIC's aren't comparable otherwise). You seem to be overthinking the range issue. Unless you have a reason to do differently, you should leave the range empty and let it be the maximum allowed by the data allowing for 12 lags.
Thanks for your reply. Appreciate that. I am a PhD candidate and at the moment learning VARs in the best manner possible, hope my questions are not annoying you. Actually when i did my ADF tests in levels i used augmented dickey fuller test, it needs first difference on the left hand side and lagged differences on left hand side. So when my original data started from 2002:06 with 1 differencing and then allowing for 12 lags my estimation started from 2003:07. I am concerned about this because if that estimation started from 2003:07 all other estimations should have the same period as well otherwise the results would not be consistent.
So that is why i am taking care about it, i am not overthinking but i want to be accurate on what i learned and what i apply.
I await your response. Thanks in advance.
Ateeb Syed
Ateeb Syed
In the unit root/cointegration literature there are two ways to count lags: the number of lags on the differences (augmenting lags) or the number of lags in the reduced form AR/VAR (what you get when you substitute back to levels). The first will be one less than the second. Both CATS and the RATS @JOHMLE procedure for doing cointegration use the second method, and @VARLAGSELECT on the levels is a consistent method of choosing the lag length for the cointegrated model.
You're correct that using (up to) 12 lags on the differences in an ADF test is really using 13 lagged values, and the similar analysis on @VARLagSelect will use 13 lags. However, you don't have to use the same number of lags in those; a univariate test can safely use more lags than a multivariate one because the latter can run into degrees of freedom issues.
Hallo Tom Doan!
I want to apply the example suggested with the @VarLagSelect procedure but I can't find a file called "GSCI_gold_and_silver.xlsx" in the Rats pack.
thank you for your help,
Widad
Widad
That is from the FVO2P254.RPF example in the Franses-Van Dijk-Opschoor textbook examples.
Dear Tom,TomDoan wrote:That is from the FVO2P254.RPF example in the Franses-Van Dijk-Opschoor textbook examples.
where can I find these textbook examples? I neither could find them in the textbook examples sub-director of RATS version 10 nor at the estima website.
Best regards
PeterF
