VAR AGARCH model (optimal weight, hedge ratio and Hedging )
Imranyousaf09
I have estimated a spillover Between gold and stock market by using VAR AGARCH model. Now, I don't know, how to calculate optimal weight, hedge ratio and hedging effectiness for these two series in RATS 10. Attached article has first applied var Garch and then calculate optimal weights, hedge ratio and hedging effectiveness.
Kindly guide me, how can i calculate.
https://www.sciencedirect.com/science/a ... 931400385X
Re: VAR AGARCH model (optimal weight, hedge ratio and Hedgi
Those are all functions only of the time-varying covariance matrices, and are computed exactly the same way regardless of the type of multivariate GARCH model you use. For an example, see Sadorsky(2012).
Imranyousaf09
Dear TomDoan,
I am first time user of RATS, and I have calculated a spillover between two series by using VAR AGARCH. Kindly guide me, what will be the different steps to calculate time varying variance of both gold and stock returns separately (and time varying covariance). After that, I will calculate weight and hedge ratio. Kindly guide me, what will be the code exactly.
"Spillover" is irrelevant to those calculations---they depend only upon the covariance matrices at each time period.
With the covariance matrices saved into HH by the HMATRICES option on GARCH, this computes the hedge ratios:
Portfolio weights can be computed with
dec rect[series] hedges(%nvar,%nvar)
do i=1,%nvar
do j=1,%nvar
if i==j
next
set hedges(i,j) = hh(t)(i,j)/hh(t)(i,i)
dec rect[series] weights(%nvar,%nvar)
do i=1,%nvar
do j=1,%nvar
if i==j
next
set weights(i,j) = $
(hh(t)(j,j)-hh(t)(i,j))/(hh(t)(i,i)-2*hh(t)(i,j)+hh(t)(j,j))
* This constrains the positions to the range[0,1]
set weights(i,j) = %min(1.0,%max(0.0,weights(i,j)))
Imranyousaf09
Thanks Tom Doan,
And how can I calculate hedging effectiveness?
Isn't the hedging effectiveness just the squared correlation?
Imranyousaf09
There is a attached documents having hedging effectiveness formula.
Now, kindly guide me, how can i calculate hedging effectiveness.
- IMG20190412200239.jpg (4.89 MiB) Viewed 33419 times
- IMG20190412200222.jpg (4.17 MiB) Viewed 33419 times
That's the general formula for any type of hedging strategy with any type of portfolio. In this case (two assets, shorting one to hedge the other), I believe it's the squared correlation.
Imranyousaf09
Kindly tell me, how can i calculate variance hedged and variance unhedged in RATS? What can be the code?
Have you read Kroner Ng(1998), section 5, which describes the type of strategy being used? (The paper you cited is relying entirely on that).
Imranyousaf09
I have calculated the spillover between Indo and gold returns. I attach the document having the code of estimation of VAR AGARCH. Now, I want to calculate weight, hedge ratio and hedging effectiveness. Kindly tell me, how can i calculate weight, hedge ratio and effectiveness, what should I write below VAR AGARCH code to calculate these three factors. I am new user, I run upper 2 codes(provided by you) , but I receive different errors. Kindly send me code in the same form as given in attached file to calculate weights, hedge ratio and hedging effectiveness between two series "Indo and gold".
Imranyousaf09
Simply, assume there are two series "indo" and "gold". Now tell me, what should write below VAR AGARCH command(as attached in last message) to calculate weight, hedge ratio and hedging effectiveness between these two series. Kindly tell me.
Please do not attach a screen shot. I can't do a thing with that. Attach a program file (.rpf) and data file.
Are you a finance student? These are calculations that come from doing variance minimization on portfolios of two(!!) assets with zero means assumed. (As I said, read Kroner and Ng). If you have the covariance matrix out of the GARCH model (again, read Kroner and Ng) those are all simple calculations on the elements of the covariance matrix. If you use HMATRICES=HH, the conditional covariance matrix at time T is HH(T). It has three elements: HH(T)(1,1) is the variance of the first asset, HH(T)(1,2) is the covariance between them, and HH(T)(2,2) is the variance of the second asset.
Imranyousaf09
I equate hmatrices with HH. But I am unable to calculate conditional variance of both series and confidence. I am beginner, I don't know, how to run code. Kindly elaborate me the procedure to calculate time varying conditional variance of both series and covariance?
The conditional covariance matrices are saved using the HMATRICES option. (See the User's Guide). They're time-varying which means they produce time-varying portfolio weights and hedge ratios (and correlations and variances, ...). The Sadorsky paper does pairwise calculations using a 3 variable GARCH model. If you just have one pair of series, then (for instance) the hedge ratios both ways (again, these are time varying) would be
set hedge1with2 = hh(t)(1,2)/hh(t)(2,2)
set hedge2with1 = hh(t)(1,2)/hh(t)(1,1)
(if you saved the covariances matrices into HH---if you use a different name, replace it in those calculations).
I don't know what you mean by "confidence".
