IRF From Estimated VECM with DCC-MGARCH
cmcknigh
Unread post by cmcknigh »
I have estimated a VECM with a DCC-MGARCH specification and I am wondering how to recover IRF's for the underlying mean equation (i.e. the VECM). I am new to RATS so any help would be greatly appreciated. My general code to estimate this system is:
equation(coeffs=cv) ecteq *
# WHEAT CORN ETHANOL GAS
system(model=basevecm)
variables WHEAT CORN ETHANOL GAS
lags 1 2
ect ecteq
estimate(residuals=resids)
garch(model=basevecm,mv=dcc,asymmetric,stdresids=stdu,hmatrices=hh,rvectors=rr,method=bhhh,iters=1000)
Re: IRF From Estimated VECM with DCC-MGARCH
You can simply do IMPULSE(MODEL=BASEVECM,other options). The one thing about impulse responses in GARCH models is that there isn't a single covariance matrix for the model like there is in the typical VAR. You would need to figure out what shock sizes you want.
cmcknigh
Thank you for your response @TomDoan. A couple of quick follow up questions. (1) How would I go about calculating confidence bands if I wanted to graph these IRF's? (2) Is the default shock simply a one standard deviation shock? and (3) I know in other statistical software like Stata and EViews, the VECM output breaks down the ECT parameter into something like 〖ECT〗_(t-1)=1.000*〖wheat〗_(t-1)-1.66876*〖corn〗_(t-1)+1.852559*〖ethanol〗_(t-1)-0.465659*〖gasoline〗_(t-1)-4.432442. However in the RATS output, I only see one estimated coefficient on the EC1{1} parameter. Is there a way to break it down? Thanks again for your help.
cmcknigh wrote: Thank you for your response @TomDoan. A couple of quick follow up questions. (1) How would I go about calculating confidence bands if I wanted to graph these IRF's?
Unfortunately, that's very complicated because the lag coefficients are being estimated as part of a non-linear estimation, so there's no simple density from which to do the simulations like there is for a VAR or a VECM without GARCH errors. It's doable, but requires a technique like Markov Chain Monte Carlo which usually requires some experimentation to get the chain to work properly.
cmcknigh wrote: (2) Is the default shock simply a one standard deviation shock?
I don't think you want that. It looks like unit shocks (or .01 shocks if you didn't multiply up by 100) would make more sense under the circumstances. (FACTOR=%IDENTITY(%NVAR) or FACTOR=.01*%IDENTITY(%NVAR) depending upon the desired scale).
cmcknigh wrote: (3) I know in other statistical software like Stata and EViews, the VECM output breaks down the ECT parameter into something like 〖ECT〗_(t-1)=1.000*〖wheat〗_(t-1)-1.66876*〖corn〗_(t-1)+1.852559*〖ethanol〗_(t-1)-0.465659*〖gasoline〗_(t-1)-4.432442. However in the RATS output, I only see one estimated coefficient on the EC1{1} parameter. Is there a way to break it down?
You can do
display ecteq
to see the linear combination used in the error correction term. I'm not sure how writing that out accomplishes much.
cmcknigh
Thanks again for this help. My data is logged price series, so what could I do if I wanted to graph a shock of 10% and not a unit increase?
The recommendation would be use 100*log(..) which makes it possible to do everything naturally as a percentage (rather than using decimals). With that, the 10% shocks to each variable would be FACTOR=10*%IDENTITY(%NVAR).
