Dear Tom;
Here is the code below to replicate the Pretesting For Multi-Step Ahead Forecasts with STAR Models, International Journal of Forecasting 31(2), 2015. pp. 473-87. I downloaded it from http://www.time-series.net/time-series_papers. But I got
"Null Hypothesis : The Following Coefficients Are Zero
DY2 Lag(s) 12
DY3 Lag(s) 12
DY4 Lag(s) 12
F(3,325)= 1.07251 with Significance Level 0.36085382
## SX11. Identifier START is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>>do cap_T = start,<<<<
Common errors are
* a space before the ( in an option field
* a missing space before = in a SET or FRML
* a missing $ at the end of a long line which continues to the next"
How can I solve it?
wert12
- all_Combined_Monthly.xls
- (367.5 KiB) Downloaded 1652 times
- sample_code.2185518.RPF
- (4.18 KiB) Downloaded 1631 times
- 1.RPF
- (1.77 KiB) Downloaded 1626 times
Re: Pretesting For Multi-Step Ahead Forecasts with STAR Mode
Note that we have had nothing to do with writing those programs. There's something clearly very wrong with that---not only is START not defined, but even if it were defined
do cap_T = start, end
box(noprint,define=ar4,constant,diffs=1,ar=4) y start cap_T
doesn't make any sense, since that would be estimating a model with one data point when CAP_T=START. I think START is supposed to be the first entry in the forecast evaluation window, and the BOXJENK instruction is supposed to be estimated over * CAP_T rather than START CAP_T.
