Reading several data arrays and performing Monte Carlo Study
Re: Reading several data arrays and performing Monte Carlo S
All instructions are described in the Help:
https://estima.com/ratshelp/sourceinstruction.html
The use of SOURCE for pulling in procedures is covered in the Introduction.
pedrocm
Post by pedrocm »
Thanks Tom.
It did work after sourcing the procedure.
I am not sure why, but when evaluating a different dataset, I am having the following problem after setting the @MSSysRegression(states=2,switch=ch):
The Error Occurred At Location 62, Line 9 of MSSYSREGINITIAL
C:\Users\Public\Documents\Estima\WinRATS Std 9.0\mssysregression.src Line 209
It happens only when I have the data imported in the loop. Any guess what is causing it?
Thanks in advance.
Aren't you changing the number of lags from sample to sample? This is setting the range based upon whatever was just done (which when i=2 is the estimation at the end of i=1). You probably need to move the non-switching VECM estimation inside the loop so it will adapt to the change in lags.
do i=1,4
pedrocm
Post by pedrocm »
Hi Tom.
Thanks for the advice. Indeed, I suspected that was the problem. I tried that yesterday and it did work. Just wanted make sure I was doing the right thing.
Thanks a lot.
