Forecast function with shocks
Could you tell me if I am understanding the output computation when a shocks variable is introduced in the forecast function correctly here:
https://estima.com/ratshelp/index.html? ... ction.html
SYSTEM(MODEL=var1)
VARIABLES v1 v2 v3 v4 v5
LAGS 1 TO 3
DET Constant
END(SYSTEM)
ESTIMATE(resids=varresids) 1985:01 2017:09
compute hstart = 2016:10
compute hend = 2017:09
forecast(paths,from=hstart,to=hend,model=var1,results=withoilshocks)
#oilshocks
where oilshocks is a 12 * 5 array of shocks series
now I am trying to understand if the following computation in R is what the forecast function does above
y <- data
var1<-reduced.form.var(y,p=3)
#intercept is a 1 * 5 array
intercept <- var1$intercept
#coefs are the coefficients without the intercept. It is a 15 * 5 array
coefs <- var1$coefs
# we reshape this coefs matrix into (nvar,nvar,nlag) for the below computation
nvar<-5
nlag<-3
dim(coefs)<-c(nvar,nvar,nlag)
capT<-nrow(y)
yhat<-rbind(y,matrix(0,ncol=nvar,nrow=nsteps))
nsteps<-12
uu=t(resid) %*% resid
nobs=length(resid)
Sh=uu/nobs
A0=t(chol(Sh))
# Compute the deterministic part of the forecasts (less the intercept!)
# Now loop over the forecast horizon
for(h in 1:nsteps)
{ yhat[capT + h, ] <- (yhat[capT + h - 1,] %*% coefs[,,1] + intercept + (shocks[h,]%*%A0))
if (p>1) {for(i in 2:p)
{ yhat[capT + h, ] <- (yhat[capT + h, ] + (yhat[capT + h - i, ] %*% coefs[,,i]))
output <- yhat
withoilshocks<-tail(output,nsteps)
Is this above logic correct
SYSTEM(MODEL=var1)
LAGS 1 TO 3
DET Constant
END(SYSTEM)
#oilshocks
y <- data
coefs <- var1$coefs
nvar<-5
nlag<-3
capT<-nrow(y)
nsteps<-12
nobs=length(resid)
Sh=uu/nobs
A0=t(chol(Sh))
for(h in 1:nsteps)
output <- yhat
Re: Forecast function with shocks
What's the origin of the "SHOCKS"?
This adjustment: (shocks[h,]%*%A0)
is multiplying the input shock matrix by the Cholesky factor of the residuals, so they are orthogonalized shocks. (Seems rather odd since the Cholesky factor isn't even known until you estimate the model).
so should I just multiply them with the shocks instead
shocks are computed as:
compute bfactor = %decomp(%sigma)
compute identvector=||1.0,1.0,0.0,0.0,1.0||
compute oil=bfactor*%diag(identvector)*inv(bfactor)
dec vect[series] oilshocks(5)
do t=hstart,hend
compute %pt(oilshocks,t,oil*%xt(varresids,t))
end do t
do t=hstart,hend
end do t
If what you're trying to do is to shut down the orthogonalized residuals for variables other than 1, 2 and 5, then that's correct.
