Markov Switching VECM
nacrointfin
Unread post by nacrointfin »
Dear All:
Can the markov switching vecm be implemented under the command 'msvarsetup'?
Terence Wan
Re: Markov Switching VECM
nacrointfin wrote:Dear All:
Terence Wan
You would have to use @MSSysRegression instead since it allows for more general equation forms. The one difference is that MSVARSETUP allows for switching means, while MSSysRegression only has switching coefficients. For an example, see Balcilar, Gupta and Miller, EE(2015)
OLUSEGUN
Unread post by OLUSEGUN »
Pls i need codes for MS TVP VECM and MS VECM
OLUSEGUN wrote:Pls i need codes for MS TVP VECM and MS VECM
For an MS-VECM see Balcilar, Gupta and Miller, EE(2015). I'm not sure what you mean by an MS TVP VECM. Did you mean TVTP (time-varying transition probabilities)?
OLUSEGUN
thanks TomDoan for the MS-VECM. For the second one, what i mean is Time - Varying Parameters (TVP) - VECM
OLUSEGUN wrote:thanks TomDoan for the MS-VECM. For the second one, what i mean is Time - Varying Parameters (TVP) - VECM
Sorry again. You mean just Time-Varying Parameters VECM, not anything with Markov Switching? (MS-TVP-VECM sounds like a model which has no chance of working).
