Var with sign restriction
Zied_bct
Dear tom
I try to evaluate the impact of exchange rate depreciation on production and price according to Uhlig (2005) Methodologies who impose a positive constrain on fed interest rate .
i must ti impose negative constraint on exchange rate . haow i do this in winrats??
Re: Var with sign restriction
See the description on https://estima.com/ratshelp/uhligjme2005.html. The UhligAccept function uses + and - signs on the variable positions to choose between a + sign restriction and a - sign restriction.
Zied_bct
TomDoan wrote:See the description on https://estima.com/ratshelp/uhligjme2005.html. The UhligAccept function uses + and - signs on the variable positions to choose between a + sign restriction and a - sign restriction.
Thank you Tom
I have another question :
How i can introduce exogeneous variable in VAR system in Uhlig's program??
What do you mean by "exogenous"?
Zied_bct
TomDoan wrote:What do you mean by "exogenous"?
fOR Example , i must introduce a dummy variable in VAR system with sign restriction
Just change the VAR to include the dummy as a DETERMINISTIC. Dummies have no effect on the impulse responses, so have no effect on the sign restriction calculations.
