Cards to enter objects different from integers?
jonasdovern
Unread post by jonasdovern »
Dear RATS users,
is it possible to program a construction that allows to enter for instance a number of equations on a supplementary card to a procedure (like it is used e.g. in the forecast-command)?
To use this procedure I would like to enter something like
@testprocedure( options )
# eqn1 eqn2 ... eqnK
Ideally, I would like to enter cards that hold different type of objects (like with the forecast-command):
# eqn1 result1
# eqnK resultK
where resultX is a series/integer/real.
I tried to define the array used with enter inside the procedure as a vec[equ] - but this seems to be not working as I receive an error message that additional memory of "-13 bytes cannot be satisfied".
Re: Cards to enter objects different from integers?
You might want to look at the CONDITION.SRC file. That uses ENTER to input a whole string of information, one per line with different fields.
jonasdovern
Thanks Tom! I think something along those lines will help me! Best regards, Jonas
jonasdovern
I guess I was too optimistic ;-)
Here's (part of) my code:
procedure nowcastwithmM ne
    option integer	ftime
    option integer	fsteps 3
    option switch	addf 0
	local int		neqn k
	local model		lmod
	local vec[ser]	fcs
	local vec[int] 	af
	local vec[equ]	eqnlist
	if eqninput.and..not.%defined(ne) {
		disp "Please enter the number of equations behind the procedure name!"
		return
	comp neqn = ne
	dim af(neqn)
	dim eqnlist(neqn)
	do k=1,neqn
        	enter eqnlist(k)
	end do
	if addf {
		enter(varying,entries=naf) af
		if naf<>neqn {
			disp "Number of add-factors does not correspond to number of equations in the model!"
			return
	else {
		do k=1,neqn
			set af(k) ftime ftime+fsteps-1 = 0.0
		end do
	do k=1,neqn
	         if k==1
			group lmod eqnlist(k)
		else
			comp lmod = lmod + eqnlist(k)
	end do
	forecast(print=print,model=lmod,from=ftime,steps=fsteps,results=fcs,path) *
	# af
	decl vec[ser] %mFCS(neqn)
	do k=1,neqn
		set %mFCS(k) ftime ftime+fsteps-1 = fcs(k)(t)
	end do k
end procedure
When running, RATS would promt the error message
## EQ3. Equation zÚ Has Not Been Defined
The Error Occurred At Location 0830 of NOWCASTWITHMM
Line 66 of NOWCASTWITHMM
(It's the forecast-command that is causing problems; the line number does not corrspond as I deleted some unimportant pieces from the code.)
The problem seems to be that the equations are not properly held by the eqnlist-array.
Best regards, Jonas
