SETAR Model: multi-step-ahead rolling forecasts
ac_1
Unread post by ac_1 »
Can a SETAR model be applied to a non-stationary series or is the only requirement to check for non-linearity? I can generate one-step ahead rolling forecasts using threshtest.src to estimate the break and to generate forecasts within a DO loop.
set onestep = setar(t)
group lsetarmodel setar
forecast(model=lsetarmodel,results=fcasts) * 1 ibegin+1+j
How do I generate multi-step-ahead rolling forecasts saving only the last forecast step as in FORECAST instruction SKIPSAVE? https://estima.com/ratshelp/index.html? ... ction.html
many thanks,
Amarjit
Re: SETAR Model: multi-step-ahead rolling forecasts
There is no closed-form formula for out-of-sample forecasting in a threshold model.
ac_1
TomDoan wrote:There is no closed-form formula for out-of-sample forecasting in a threshold model.
Not even for one-step ahead? I have read on the Web, static or one-step ahead forecasting is straightforward and uses the estimated equations.
If not straightforward, then I guess simulations to generate out-of-sample forecasts? Right? Please can you provide an example to generate one-step ahead and multi-step-ahead rolling forecasts.
ac_1
Based on Example 4.1 TAR Model for Unemployment, here's an attempt at recursive STATIC ONE-STEP AHEAD FORECASTS generated from a SETAR model. Please can you have a look - I think it's correct.
* RECURSIVE STATIC ONE-STEP AHEAD OOS FORECASTS
seed 550103
clear(length=2010:10) urfore_1
do regend = 2010:10-13, 2010:10
@threshtest(thresh=dur,d=1,nreps=100) dur * regend
# constant dur{1 to 4}
compute break1=%%breakvalue
disp break1
* Estimate the two branches and define equations
linreg(smpl=dur{1}<=break1,frml=branch1) dur * regend
compute rss1=%rss,ndf1=%ndf
linreg(smpl=dur{1}>break1,frml=branch2) dur * regend
compute rss2=%rss,ndf2=%ndf
compute seesq=(rss1+rss2)/(ndf1+ndf2)
* Define the forecasting model
frml(variance=seesq) tarfrml dur = $
      %if(dur{1}<=break1,branch1,branch2)
frml(identity) urid unrate = unrate{1}+dur
group tarmodel tarfrml urid
* Compute average across simulations
compute fstart=regend,fend=regend
set urfore_1 regend regend = 0.0
compute ndraws=5000
do draw=1,ndraws
   simulate(model=tarmodel,from=regend,to=regend,results=sims_1,noprint)
   set urfore_1 regend regend = urfore_1+sims_1(2)
end do draw
set urfore_1 regend regend = urfore_1/ndraws
end do regend
graph(footer="RECURSIVE STATIC ONE-STEP AHEAD OOS FORECASTS") 2
# unrate regend-13 regend
# urfore_1
prin fstart-13 regend unrate urfore_1
How do I calculate forecast SE's for Prediction intervals?
I also want to compute nth-step-ahead forecasts, DYNAMIC MULTISTEP AHEAD OOS FORECASTS and save only the nth forecast step from each recursive multistep ahead simulation...
many thanks,
Amarjit
ac_1
I've managed to generate STATIC ONE-STEP AHEAD OOS FORECASTS, adjusting via regend+1 in SIMULATE; and have generated DYNAMIC MULTISTEP AHEAD OOS FORECASTS saving only the nth forecast step.
The question is how to simulate the forecast SE's, which are method specific e.g. SETAR-AR(p), for prediction intervals?
ac_1 wrote:I've managed to generate STATIC ONE-STEP AHEAD OOS FORECASTS, adjusting via regend+1 in SIMULATE; and have generated DYNAMIC MULTISTEP AHEAD OOS FORECASTS saving only the nth forecast step.
Theoretically, what you are doing is generating a sample of size N from the population of values for the process conditional on the last observed value. The "forecast" is the mean of that population. The standard error of forecast is the standard error of that distribution.
ac_1
TomDoan wrote: Theoretically, what you are doing is generating a sample of size N from the population of values for the process conditional on the last observed value. The "forecast" is the mean of that population. The standard error of forecast is the standard error of that distribution.
Here's an attempt. Correct?
compute ndraws=5000
do draw=1,ndraws
   simulate(model=tarmodel,from=regend+1,to=regend+1,results=sims_1,noprint)
   set urfore_1 regend+1 regend+1 = urfore_1+sims_1(2)
   set urfore_1_M regend+1 regend+1 = urfore_1/draw
   set urfore_1_VAR regend+1 regend+1 = urfore_1_VAR + ((sims_1(2)-urfore_1_M)^2)/draw
   set urfore_1_SE regend+1 regend+1 = sqrt(urfore_1_VAR)
end do draw
No. The averages are done outside the loop. Inside, you accumulate the sums and sums of squares (since you don't know the mean, you just do raw sums of squares), then convert to mean and variance/standard error outside the loop.
ac_1
TomDoan wrote:No. The averages are done outside the loop. Inside, you accumulate the sums and sums of squares (since you don't know the mean, you just to raw sums of squares), then convert to mean and variance/standard error outside the loop.
A better attempt :) . Correct?
compute ndraws=5000
do draw=1,ndraws
   set urfore_1_SS regend+1 regend+1 = urfore_1_SS+(sims_1(2))^2
end do draw
set urfore_1_M regend+1 regend+1 = urfore_1/ndraws
set urfore_1_MSS regend+1 regend+1 = urfore_1_SS/ndraws
set urfore_1_SE regend+1 regend+1 = sqrt(urfore_1_MSS-(urfore_1_M)^2)
That looks correct. You might need to experiment with the number of draws to see how many it takes to get the standard errors to stabilize. 5000 may be (probably is) enough for the mean itself, but might not be for the standard errors.
ac_1
Generating the following with SIMULATE:
1. DYNAMIC h-MULTISTEP AHEAD OOS FORECASTS
2. STATIC ONE-STEP AHEAD OOS FORECASTS
3. DYNAMIC h-MULTISTEP AHEAD OOS FORECASTS saving only the (e.g) 4th forecast step
With the same seed, repeated, before each of the above 1-3, I should get identical MC forecasts comparing:
(a) DYNAMIC h-MULTISTEP AHEAD OOS FORECASTS vs. STATIC ONE-STEP AHEAD OOS FORECASTS; for the 1st forecast
(b) DYNAMIC h-MULTISTEP AHEAD OOS FORECASTS vs. DYNAMIC h-MULTISTEP AHEAD OOS FORECASTS saving only the 4th forecast step; for the (first) 4th forecast
as I do for LINEAR forecasts, but I do not. Why would that be?
Calculations with random numbers are only guaranteed to give identical results with a set SEED if the instructions executed are identical---it's basically for reproducing an entire program. It's possible for two different instructions to give at least some results which are the same, but that's just blind luck---it depends upon the internal order of the random draws. For instance, if you do
SEED 534323
compute a1=%ranmat(10,1),a2=%ranmat(10,1)
SEED 534323
compute b=%ranmat(20,1)
the first 10 elements of B will match A1, but the second 10 won't match A2 because firing up the second %RANMAT to get A2 changes the random number generation.
Last bumped by TomDoan on Tue Apr 05, 2022 2:45 pm.
