spgraph combining fields
ac_1
Unread post by ac_1 »
As in the Sample Graph https://estima.com/ratshelp/index.html? ... ction.html, can the fields be combined, e.g. is there a way to have 3 graphs differing in size:
1 in first column (all the way down), 2 in the 2nd column, or
1 in the first row (all the way across) and 2 in the 2nd row ?
thanks,
Amarjit
Re: spgraph combining fields
You can nest SPGRAPH instructions to do that. (The right field in the outer SPGRAPH is a 2 vertical pane SPGRAPH):
set x1 1 100 = %ran(1.0)
set x2 1 100 = %ran(1.0)
set x3 1 100 = %ran(1.0)
spgraph(hfields=2,vfields=1)
 graph
 # x1
 spgraph(hfields=1,vfields=2)
  graph
  # x2
  graph
  # x3
ac_1
Great - thanks!
