I am interested in evaluating density forecast accuracy.
I can evaluate distributional forecasts as per Continuous Ranked Probability Score (CRPS): https://otexts.com/fpp3/distaccuracy.html
An interesting paper:
Wagner Piazza Gaglianone & Gabriel Jaqueline Terra Moura Marins, 2017. "Evaluation of Exchange Rate Point and Density Forecasts: an application to Brazil," International Journal of Forecasting Volume 33, Issue 3, July–September 2017, pp. 707-728
Working paper: https://www.bcb.gov.br/pec/wps/ingl/wps446.pdf
I would like to compute the following accuracy measures as listed in B2 - Full-density forecast, in RATS, especially
(a) Probability Integral Transform (PIT)
(b) Log Predictive Density Score (LPDS)
and any others of interest, similar to CRPS, for the whole forecast distribution.
If I generate fan charts for 3 simple models, assuming the distribution of forecasts is normal, as below, how do I calculate the PIT distribution's (which are usually compared & plotted to U(0,1) histograms, the more similar, the better the density forecast), and LPDS, for each of the 3 models?
thanks,
Amarjit
* read in data
OPEN DATA "/Users/Shared/RATS/Examples/g10xrate.xls"
DATA(FORMAT=XLS,NOLABELS,ORG=COLUMNS,TOP=2) 1 6237 USXJPN USXFRA USXSUI USXNLD USXUK $
USXBEL USXGER USXSWE USXCAN USXITA
* choose series
set y = usxjpn
compute steps=25
compute istart=6000
compute iend=6237-steps
* (1) rwwd (rw without drift) or naive model
boxjenk(diffs=1,define=foreeq_rwwd) y istart iend
uforecast(equation=foreeq_rwwd,from=(iend+1),steps=steps+1,stderrs=stderrs_rwwd) yhat_rwwd
set l95_rwwd iend+1 iend+steps+1 = yhat_rwwd+%invnormal(.025)*stderrs_rwwd
set u95_rwwd iend+1 iend+steps+1 = yhat_rwwd+%invnormal(.975)*stderrs_rwwd
* (2) rwd (rw with drift) model
boxjenk(diffs=1,constant,define=foreeq_rwd) y istart iend
uforecast(equation=foreeq_rwd,from=(iend+1),steps=steps+1,stderrs=stderrs_rwd) yhat_rwd
set l95_rwd iend+1 iend+steps+1 = yhat_rwd+%invnormal(.025)*stderrs_rwd
set u95_rwd iend+1 iend+steps+1 = yhat_rwd+%invnormal(.975)*stderrs_rwd
* (3) mean/constant model
boxjenk(diffs=0,constant,define=foreeq_mean) y istart iend
uforecast(equation=foreeq_mean,from=(iend+1),steps=steps+1,stderrs=stderrs_mean) yhat_mean
set l95_mean iend+1 iend+steps+1 = yhat_mean+%invnormal(.025)*stderrs_mean
set u95_mean iend+1 iend+steps+1 = yhat_mean+%invnormal(.975)*stderrs_mean
