Confidence band on barchart
rotweiller
Unread post by rotweiller »
I know this is a stupid question, but I am trying to put 95%-Bartlett Confidence Band on a Barchart for three days now, without any success.
When I define the upper and lower boundary as
set upper = ( 1.96*(1/sqrt(%nobs)))
set lower = ( - 1.96*(1/sqrt(%nobs)))
and the try to graph it with vgrid option with the graph command I was only able to put one of the boundaries at time. I have read everything about graphs from the User Book, and from the Reference Guide also have tried googleing and I still don't have any idea. My actual goal is to put the Diebold corrected confidence band so 4 boundaries on one graph, two up and two down.
Any help would be usefull![/b]
rotweiller
Problem solved!
Problem solved!
When somebody wants know how read the bjest.src there is an example!
