a question about @disaggregate
hardmann
Unread post by hardmann »
Dear Tom:
I understand a instruction in model 2, 'Log linear model', in @disaggregate procudure as follows.
frml cf     = lc=lcf,cv=%zeros(ndlm,1),%do(i,1,factor,%(cv(i)=mx(i)=lc(i)*exp(xstate0(t)(i)))),cv
Howerver, I do not know why do it as such way. It feels like forcing a few instructions into one instruction. Is a instruction mandatory and can it be expanded into multiple instruction.
Pls Tom explain it in detail.
Best Regard
Hardmann
Re: a question about @disaggregate
The only alternative would be to write a FUNCTION of T which returns a VECTOR and make FRML CF reference that. But it's a FRML which depends upon T, both because of the obvious (reference to XSTATE0(T)), but also because LCF itself is a FRML. The linearized state-space model is complicated.
