Recursive VECM - Johansen ML technique
ac_1
Re: Recursive VECM - Johansen ML technique
Unread post by ac_1 »
TomDoan wrote: Mon Mar 18, 2024 9:23 am
ac_1 wrote: Mon Mar 18, 2024 2:59 am (ii) To aid my understanding, given a VAR-in-levels with DET=NONE or DET=CONSTANT I can manually calculate the PI matrix
PI = - (I - GAMMA(1) - GAMMA(2) - ... - GAMMA(p))
where
I is the identity matrix
GAMMA's are the matrices of parameters up to the AR(pth) lag.
How to 'by-hand' calculate PI including the deterministic terms: DET=RC, DET=TREND, and SEASONAL?
DET=RC and DET=RTREND are the only ones that are more complicated, and that is only because they anticipate a restriction on the intercept (or trend). The adjusted "PI" matrix in rearranging the unrestricted VAR simply adds a column of the estimates on the constant (DET=RC) and trend term (DET=RTREND).
Probably easier to include
comp PI = loadings*tr(vectors))
to calculate PI in JohMLE.src
From, https://www.estima.com/ratshelp/index.h ... edure.html
DET=NONE/[CONSTANT]/TREND/RC, should be RTREND to get the additional column of estimates, although @JOHMLE accepts TREND as-well?
(vii) If I run my acmtsICRS.src procedure for plotting of the inverse roots.
I get an error
Dimension Companion matrix
## MAT1. Matrix COMPANION Has Not Been Dimensioned
Here
* AR roots
if (mts == 0)
   compute companion=%modelcompanion(mtsmodel)
   eigen(cvalues=mtsroots) companion
if (mts == 1)
   compute companion=%modelcompanion(%modelsubstect(mtsmodel))
acmtsICRS.src is to be used for any VAR and VECM.
How to declare the dimension of the Matrix beforehand?
ac_1 wrote: Wed Mar 20, 2024 3:40 am (vii) If I run my acmtsICRS.src procedure for plotting of the inverse roots.
I get an error
Here
* AR roots
if (mts == 0)
if (mts == 1)
That's not how IF's work in RATS. You need braces around the controlled instructions.
ac_1
TomDoan wrote: Wed Mar 20, 2024 9:37 am
I get an error
Here
* AR roots
if (mts == 0)
if (mts == 1)
* AR roots
if (mts == 0) {
   eigen(cvalues=mtsroots) companion }
if (mts == 1) {
I get the following error
## SX22. Expected Type VECTOR[REAL], Got INTEGER Instead
>>>>sroots) companion }<<<<
Put the close } on a new line.
ac_1
TomDoan wrote: Wed Mar 20, 2024 7:21 pm Put the close } on a new line.
ac_1 wrote: Wed Mar 20, 2024 3:40 am From, https://www.estima.com/ratshelp/index.h ... edure.html
We've updated that, but note well that DET=TREND means that 1 and t are included in the regressions which, in the presence of unit roots, will create a quadratic trend. Needless to say, there isn't much call for that. Trending data are usually handled reasonably with DET=CONSTANT. DET=RTREND is really only useful when there are trending data, but it's not clear if the series actually have unit roots. (Unit roots plus DET=CONSTANT creates trends, but stationary data will not).
ac_1
TomDoan wrote: Thu Mar 21, 2024 12:47 pm
Thanks! You may want to update the Output https://www.estima.com/ratshelp/index.h ... edure.html as these are the results with RATS 10.00 version c.
The Rank 0 row is for the differenced model
Likelihood Based Analysis of Cointegration
Variables:  FTBS3 FTB12 FCM7
Estimated from 1975:07 to 2001:06
Data Points 312 Lags 6 with Constant restricted to Cointegrating Vector
  Rank     EigVal  Lambda-max  Trace   Trace-95%  LogL
        0                                        20.2392
        1   0.0818    26.6264  41.2013   35.0700 33.5524
        2   0.0333    10.5567  14.5750   20.1600 38.8307
        3   0.0128     4.0183   4.0183    9.1400 40.8399
FTBS3     FTB12    FCM7       Constant
-3.154123 3.132882  -0.321838 0.619010
Harris, R (1995) Using Cointegration Analysis in Econometric Modelling, Pearson Educaton Limited, Prentice Hall,
is a good book which uses CATS, amongst other packages (I would like CATS 2.0 at sometime in the future).
We changed the format of the output to match the general CATS rank test statistics. We can't change help files on older software.
ac_1
To complement individual variable residual plots as in ARIMA models (i) time plot (ii) ACF (iii) histogram with normal density (iv) qplot (normal); regarding multivariate residual tests (as a 'generic' battery) for a VAR and VECM (e.g. 3 variable) are these exhaustive and with the correct options/parameters?
CROSS(qstats,org=columns,from=-8,to=8) resids(1) resids(2)
@CROSSCORR(number=20) resids(1) resids(2)
CROSS(qstats,org=columns,from=-8,to=8) resids(1) resids(3)
@CROSSCORR(number=20) resids(1) resids(3)
CROSS(qstats,org=columns,from=-8,to=8) resids(2) resids(3)
@CROSSCORR(number=20) resids(2) resids(3)
* multivariate residual heteroskedasticity test
* https://estima.com/ratshelp/index.html?archtestprocedure.html
* H0: is that the series are mean zero, not serially correlated and with a fixed covariance matrix
* p = 0 reject the null; p >= 0.05 cannot reject the null
@mvarchtest(lags=5)
# resids
* multivariate residual Hosking(1981) variant of the multivariate Q statistic
* https://estima.com/ratshelp/index.html?mvjbprocedure.html
* H0: No serial correlation
comp k=4; comp plag=4
@mvqstat(dfc=(plag*k^2),lags=12)
# resids
* multivariate residual stability test in Nyblom(1989) for a complete covariance matrix
* H0: null is that the covariance matrix of the series is constant vs an alternative of a structural break at some point in the sample.
@cvstabtest
# resids
* multivariate residual normality test
* H0: The null hypothesis is a joint hypothesis of the skewness being zero and the excess kurtosis being zero.
@mvjb(sigma=%sigma)
# resids
Exhaustive is a bit strong. Those look fine.
ac_1
(a) In a cointegrated VECM for I(1) variables:
- Is it worth plotting the IRF's as they are not mean reverting, as per unit roots relative to the complex unit circle?
- What about variance decompositions?
(b) I'd like to delve deeper into the 5 determininstic components in @JOHMLE
CASE 1: None
CASE 2: Constant
CASE 3: Trend
CASE 4: Restricted constant
CASE 5: Restricted trend
To aid my understanding, I can manually calculate the PI matrix from the levels estimation for CASE 1 and CASE 2 --- Constant calculation here, but not for the others. How? Although the PI matrix is formed from the residual product moment matrices, Box 5.1, Harris (1995).
* VAR (lag=1 to 6, DET=CONSTANT)
system(model=ratemodel)
variables ftbs3 ftb12 fcm7
lags 1 to 6
estimate(residuals=resids,noftests) 1975:07 2001:06-nsteps
disp %BETASYS
disp %VARLAGSUMS; * -PI matrix
dec rectangular ID A1 A2 A3 A4 A5 A6
dim ID(3,3) A1(3,3) A2(3,3) A3(3,3) A4(3,3) A5(3,3) A6(3,3)
disp %identity(3)
comp ID = || -1.0, 0.0, 0.0 | $
             0.0, -1.0, 0.0 | $
             0.0, 0.0, -1.0 ||
disp ID
comp A1 = || %BETASYS(1), %BETASYS(7), %BETASYS(13) | $
             %BETASYS(20), %BETASYS(26), %BETASYS(32) | $
             %BETASYS(39), %BETASYS(45), %BETASYS(51) ||
disp A1
comp A2 = || %BETASYS(2), %BETASYS(8), %BETASYS(14) | $
             %BETASYS(21), %BETASYS(27), %BETASYS(33) | $
             %BETASYS(40), %BETASYS(46), %BETASYS(52) ||
disp A2
comp A3 = || %BETASYS(3), %BETASYS(9), %BETASYS(15) | $
             %BETASYS(22), %BETASYS(28), %BETASYS(34) | $
             %BETASYS(41), %BETASYS(47), %BETASYS(53) ||
disp A3
comp A4 = || %BETASYS(4), %BETASYS(10), %BETASYS(16) | $
             %BETASYS(23), %BETASYS(29), %BETASYS(35) | $
             %BETASYS(42), %BETASYS(48), %BETASYS(54) ||
disp A4
comp A5 = || %BETASYS(5), %BETASYS(11), %BETASYS(17) | $
             %BETASYS(24), %BETASYS(30), %BETASYS(36) | $
             %BETASYS(43), %BETASYS(49), %BETASYS(55) ||
disp A5
comp A6 = || %BETASYS(6), %BETASYS(12), %BETASYS(18) | $
             %BETASYS(25), %BETASYS(31), %BETASYS(37) | $
             %BETASYS(44), %BETASYS(50), %BETASYS(56) ||
disp A6
comp PIVAR = ID + A1 + A2 + A3 + A4 + A5 + A6; disp 'PIVAR:' PIVAR
ac_1 wrote: Fri Apr 05, 2024 3:11 am (a) In a cointegrated VECM for I(1) variables:
Yes and yes. While the variances diverge, the decomposition converges. See, for instance, the Hasbrouck paper, which does a long-run variance decomposition.
ac_1 wrote: Fri Apr 05, 2024 3:11 am (b) I'd like to delve deeper into the 5 determininstic components in @JOHMLE
CASE 1: None
CASE 2: Constant
CASE 3: Trend
lags 1 to 6
disp %BETASYS
disp %identity(3)
             0.0, -1.0, 0.0 | $
             0.0, 0.0, -1.0 ||
disp ID
disp A1
disp A2
disp A3
disp A4
disp A5
disp A6
Those have non-standard distributions so you can't use IC's to choose among them. I don't even know how much work anyone has done on comparisons among those---they are inextricably linked to the rank of cointegration. (For instance, DET=RC has only r "constants", rather than a full set). Because of that, you can only back out the estimates in certain cases. Note that CATS assumes the DET is known before going about the analysis.
