Problem with boxjenk and garch, rats closes
rotweiller
Post by rotweiller »
after i put this code in the programm
set difflogusdgbp = logusdgbp - logusdgbp{1}
boxjenk(ar=1, ma=1, constant, define=arma11) difflogusdgbp
everything works fine, but after
garch(p=1, q=1,constant,equation=arma11)
RATS terminates suddenly, without any warning!
If anyone has an idea, please respond here![/code]
rotweiller
Problem solved!
garch.src works fine for me!
moderator
Site Admin
Post by moderator »
The built-in GARCH command is far superior to using the old GARCH procedure in terms of speed and the range of models supported, so it would probably make sense to get to the bottom of the problem.
If you can email me a copy of your program and data files at
support@estima.com
we can take a look and see what is happening.
Please remember to include your serial number, and also let me know which version of RATS you are using (do Help-About RATS to check).
