question on IF-ELSE condition
This is the development of a 2nd Edition of Enders' RATS Programming Manual.
Moderator: TomDoan
hardmann
Post by hardmann »
Dear Tom:
I encountered a if-else problem. I copy code from RATS Programming Manual(2ed), p153.
It works, the code below the asterisk line is not executed.
do rep=1,100
compute r=%ran(1.0)
if r<-2.0
disp "Big Negative value" r
else
if r<2.0
disp "Between -2 and 2" r
else
disp "Big Positive value" r
end do rep
disp "************"
* compute r = 0.56577
if r<-2.0
else
if r<2.0
else
I do not know why.
Best Regard
Hardmann
varcabic
Re: question on IF-ELSE condition
Post by varcabic »
The first part of your code is inside the loop, so if-else works without parenthesis. The other part, after ****** is outside the loop. So, in order to work, if-else condition should be inside the parenthesis. Thy this:
disp "************"
if r<-2.0
else
if r<2.0
else
hardmann
Post by hardmann »
Dear varcabic:
I want to know why parentheses are added?
best regard
Hardmann
An IF-ELSE block outside of a more complicated program segment (your first example was inside a DO loop) requires something to indicate when you are done with the compiler logic. That's either by including the whole segment in {...} or by using an END IF.
https://estima.com/webhelp/topics/compiledsections.html
hardmann
Post by hardmann »
Dear Tom:
Thanks. I completely understand. In other programming languages, the integrity of the If-else-end if block is emphasized, and I thought Rats had an internal mechanism for completion.
Best Regard
Hardmann
