GMAUTOFIT
ac_1
GMAUTOFIT
Unread post by ac_1 »
Shouldn't GMAUTOFIT.SRC https://estima.com/webhelp/topics/gmaut ... edure.html take into account outliers?
Using AUTOBOX.RPF as an example I get very different residual autocorrelation structure and histogram, using no outliers in BOXJENK vs. OUTLIERS=STANDARD.
* AC_AUTOBOX.RPF
cal(m) 1992:1
open data x12test.xls
data(format=xls,org=columns) 1992:1 2008:7 u11bvs
* transformations
diff u11bvs / du11bvs
set ldata = log(u11bvs)
diff ldata / dldata
prin /
spgraph(hea='u11bvs\\Levels & 1st-Difference',vfi=2,hfi=1)
graph(header="", key=upleft) 1
# u11bvs
# du11bvs
spgraph(hea='ldata\\Levels & 1st-Difference',vfi=2,hfi=1)
# ldata
# dldata
* automated choice for the DIFFS, SDIFFS and CONSTANT options on a BOXJENK instruction
@bjdiff(diffs=2,SDIFFS=1) ldata
* computing and graphing the autocorrelations
* Correlogram of ldata
@bjident(diffs=%%autod,SDIFFS=%%autods) ldata
@gmautofit(diffs=%%autod,sdiffs=%%autods,const=%%autoconst,report) ldata
dec vect[labels] methodlabl(7)
compute methodlabl(1)="const"
compute methodlabl(2)="ar"
compute methodlabl(3)="diffs"
compute methodlabl(4)="ma"
compute methodlabl(5)="sar"
compute methodlabl(6)="sdiffs"
compute methodlabl(7)="sma"
display @@^10 methodlabl
declare vector[integer] parameters(7)
compute parameters(1)=%%autoconst
compute parameters(2)=%%autop
compute parameters(3)=%%autod
compute parameters(4)=%%autoq
compute parameters(5)=%%autops
compute parameters(6)=%%autods
compute parameters(7)=%%autoqs
display @@^10 parameters
boxjenk(diffs=%%autod,sdiffs=%%autods,const=%%autoconst,$
  ar=%%autop,sar=%%autops,ma=%%autoq,sma=%%autoqs,define=eq_D) ldata / resids
@regcrits
set fit / = ldata - resids
prin / ldata fit resids
* Actual vs fitted and residuals ARIMA-GM-BIC
spgraph(hea='ldata',vfi=1,hfi=1)
@REGACTFIT
* Residual Plots & Tests
spgraph(hfields=2,vfields=1)
   @regcorrs(header="acf plot for residuals",dfc=%narma,number=25,qstats,report,method=YULE) resids
   @histogram(header="histogram for residuals with overlay of the normal density",distrib=normal,MAXGRID=60) resids
  ar=%%autop,sar=%%autops,ma=%%autoq,sma=%%autoqs,define=eq_D,$
  outliers=standard) ldata / resids
@regcrits
@REGACTFIT
Plotting u11bvs and ldata visually there appears to be no outliers.
Yet fitting both BOXJENK models
* there is an outlier
* 1994:01 0.140773209247
flat residual ACF, non-normal residuals
and using
* no outlier
* 1994:01 0.096017402284
NOT a flat residual ACF, normal residuals
So isn't GMAUTOFIT identifying the wrong model as OUTLIERS are not being taken into account?
In otherwords, the logic isn't correct in the modelling process.
In general, for any series, the main aim being a flat residual ACF structure, then normal residuals (as bootstrapping can handle non-normality for a simple AR model). Right?
Importantly, at what STAGE in the modelling procedure do I take outliers into account (say, if not using OUTLIERS in BOXJENK but manual pulse dummies)?
thanks,
Amarjit
Re: GMAUTOFIT
The short answer is no. And if you look at the output, the estimation with OUTLIERS doesn't find any outliers. The difference between the estimators is that (non-empty) OUTLIERS option forces use of maximum likelihood while the other estimation is doing Gauss-Newton. The two aren't comparable (aside from using different objective functions, MAXL is able to use extra data points).
While ideally you want residuals to pass a test for whiteness, there is no particularly strong reason to be concerned about non-normality.
ac_1
Re: GMAUTOFIT
TomDoan wrote: ↑Fri Apr 18, 2025 7:58 am The short answer is no. And if you look at the output, the estimation with OUTLIERS doesn't find any outliers. The difference between the estimators is that (non-empty) OUTLIERS option forces use of maximum likelihood while the other estimation is doing Gauss-Newton. The two aren't comparable (aside from using different objective functions, MAXL is able to use extra data points).
Yes, MAXL in BOXJENK can use extra data points.
TomDoan wrote: ↑Fri Apr 18, 2025 7:58 am While ideally you want residuals to pass a test for whiteness, there is no particularly strong reason to be concerned about non-normality.
Why?
Also, generally, at what STAGE in the modelling procedure do I take outliers into account? As in this example plotting u11bvs and ldata visually there appears to be no outliers.
Re: GMAUTOFIT
ac_1 wrote: ↑Fri Apr 18, 2025 9:49 am
Why?
The better question is why would you expect them to BE normally distributed? There's over 40 years of work showing that the assumption of Gaussianity isn't necessary for much of anything.
ac_1 wrote: ↑Fri Apr 18, 2025 9:49 am Also, generally, at what STAGE in the modelling procedure do I take outliers into account? As in this example plotting u11bvs and ldata visually there appears to be no outliers.
The Census Bureau procedure selects a basic time series model, uses it to identify outliers (if any), strips the outlier effects from the data, analyzes the cleaned-up data, then adds the outliers back in at the end.
