garchmvbootstrap.rpf
ac_1
Re: garchmvbootstrap.rpf
Please can you fix - the procedure does not run correctly.
ac_1
I'll presume for whatever reasons the new code cannot be adapted into a procedure.
Also, whilst Wald test using QMLE adjustment or maybe Wald with HAC adjustment (will they be almost identical?), should be able to help to judge multi-step VaR forecasts using overlapping returns, I am not certain they are the answer.
IMHO Block Bootstrapping Kupiec (ideally as a procedure) is a much better solution for financial returns:
https://estima.com/RATSBetaHelp/topics/ ... pping.html
https://estima.com/RATSBetaHelp/topics/ ... aprpf.html
ac_1
Here's an attempt at Block Bootstrap Kupiec, as a minimal procedure.
There is a small difference (4th decimal place...) in the results for
%%pofbootse from the STATS instruction i.e. all the ndraws of the POF's stored as a vector
vs.
the Alternative acsum method, not sure why that would be?
Please can you see if the procedure is correct/incorrect.
vs.
procedure acKupiecBlockBoot trigger start end
type series trigger
type integer start end
local integer startl endl draw
local integer Nobs kobs kboot
local integer blocklen
local real violratio alphahat alphahatboot
local real pofobs pofboot countextreme
local series[integer] bootentries
local series H0DIST bootviol
local real acsum acsum_SS res_S_M res_S_MSS res_S_SE
option real alpha .01
option real siglevel .05
option integer ndraws 10000
option integer horizon 1
local series temp gPOFBoot fPOFBoot
local series pofbootdist
inquire(reglist) startl<<start endl<<end
# trigger
* --- Set block length ---
compute blocklen = horizon
* --- Calculate observed statistics ---
sstats(mean) startl endl trigger>>alphahat
compute Nobs = %nobs
compute kobs = fix(alphahat*Nobs)
compute violratio = alphahat
* --- Observed POF statistic ---
if (kobs>0.and.kobs<Nobs)
compute pofobs=2*Nobs*((1-alphahat)*log((1-alphahat)/(1-alpha))+alphahat*log(alphahat/alpha))
else if (kobs==0)
compute pofobs=-2*Nobs*log(1-alpha)
else
compute pofobs=-2*Nobs*log(alpha)
* --- BLOCK-BOOTSTRAPPING ---
* --- Calculate p-value ---
compute countextreme = 0.0
compute acsum = 0.0
compute acsum_SS = 0.0
* --- Block Bootstrap series ---
set pofbootdist 1 ndraws = 0.0
* --- Block Bootstrap loop ---
do draw=1,ndraws
* STEP 1: Generate fresh H0DIST for this replication
set H0DIST startl endl = %if(%ranflip(alpha),1.0,0.0)
* STEP 2: Resample H0DIST in blocks to create serial dependence
BOOT(block=blocklen) bootentries startl endl startl endl
set bootviol startl endl = H0DIST(bootentries(t))
* STEP 3: Calculate bootstrap POF statistic
sstats(mean) startl endl bootviol>>alphahatboot
compute kboot = fix(alphahatboot*Nobs)
if (kboot>0.and.kboot<Nobs)
compute pofboot=2*Nobs*((1-alphahatboot)*log((1-alphahatboot)/(1-alpha))+alphahatboot*log(alphahatboot/alpha))
else if (kboot==0)
compute pofboot=-2*Nobs*log(1-alpha)
else
compute pofboot=-2*Nobs*log(alpha)
* Store pof bootstrap to a vector pofbootdist for POF statistics and density plot
compute pofbootdist(draw) = pofboot
* STEP 4: Count if bootstrap statistic > observed
if (pofboot>pofobs)
compute countextreme = countextreme + 1.0
* Alternatively
compute acsum = acsum+pofboot
compute acsum_SS = acsum_SS+(pofboot)^2
end do draw
* --- Store results ---
compute %%pofboot = countextreme/ndraws
* https://estima.com/RATSBetaHelp/topics/grangerbootstraprpf.html
* Compute the percentiles of the test statistics
stats(fractiles) pofbootdist 1 ndraws
compute %%pofbootmean = %mean
compute %%pofbootse = sqrt(%variance)
* CONFIRMATION
* Figure out the bootstrapped p-value (SAME AS %%pofboot)
sstats(mean) 1 ndraws (pofbootdist>pofobs)>>pvalue
disp "Bootstrapped p-value" pvalue
* Alternatively
compute res_S_M = acsum/ndraws
compute res_S_MSS = acsum_SS/ndraws
compute res_S_SE = sqrt(res_S_MSS-(res_S_M)^2)
disp 'res_S_M' res_S_M
disp 'res_S_SE' res_S_SE
* --- Plot density function for pofbootdist ---
* convert VECTOR to a SERIES for plotting
set temp 1 ndraws = pofbootdist(t)
density(smoothing=2.0) temp 1 ndraws gpofboot fpofboot
* 10 horizons, 10 colours
compute col = %if(horizon==1,2,$
%if(horizon==2,4,$
%if(horizon==3,5,$
%if(horizon==4,6,$
%if(horizon==5,7,$
%if(horizon==6,8,$
%if(horizon==7,9,$
%if(horizon==8,10,$
%if(horizon==9,11,12)))))))))
spgraph(hea="",vfi=1,hfi=1)
scatter(key=upright,head="A non-parametric empirical approximation to the sampling distribution\\of the POF statistic under H0 with serial dependence",$
footer="horizon="+%strval(horizon,"#")+", "+$
"POF mean under H0 (bootstrap):"+%strval(%%pofbootmean,".####")+", "+$
"p-value (bootstrap):"+%strval(%%pofboot,".####"),$
hgrid=||%%pofbootmean||,style=line) 1
# gpofboot fpofboot 1 ndraws col
* --- Output Results ---
display "======================================="
display "--- Block Bootstrap Kupiec POF Test ---"
display "From "+%datelabel(startl)+" to "+%datelabel(endl)
display "Horizon (h):" horizon
display "Block length:" blocklen
display
display "--- Sample Statistics ---"
display "Sample size (N):" Nobs
display "Observed exceedances (k):" kobs
display "Violation ratio (k/N):" violratio
display "Target alpha:" alpha
display
display "--- Test Configuration ---"
display "Significance level:" siglevel
display "Bootstrap replications:" ndraws
display
display "--- Test Results ---"
display "POF statistic (observed):" pofobs
display "POF mean under H0 (bootstrap) approximately 1.0:" %%pofbootmean
display "POF se under H0 (bootstrap):" %%pofbootse
display "p-value (bootstrap):" %%pofboot
display "=========================================="
end acKupiecBlockBoot
ac_1
If there are 0 or 1 or 2 exceedances, but not >=3, why does Wald QMLE give a p-value of exactly 0.0 ?
I'm not sure what it is that you think that procedure is doing, but it's not block bootstrapping. The only thing that you are reshuffling are the independently drawn random numbers, and reshuffling independent random numbers produces independent random numbers.
ac_1
It doesn't work for 0 because there is nothing in the formula that forces the alphahat to [0,1] when there are no data points that apply to the log(alphahat). And even if it's tweaked to limit the alphahat, the asymptotics don't work when the parameter is on the boundary. (The same is true for the standard likelihood ratio test)
It should work fine for small positive numbers,
ac_1
Thanks.TomDoan wrote: ↑Thu Jan 22, 2026 11:44 am It doesn't work for 0 because there is nothing in the formula that forces the alphahat to [0,1] when there are no data points that apply to the log(alphahat). And even if it's tweaked to limit the alphahat, the asymptotics don't work when the parameters is on the boundary. (The same is true for the standard likelihood ratio test).
ac_1
How do I fix so that it is block bootstrapping the Kupiec statistic properly, and thus is able to correctly assess multi-step ahead VaR forecasts.TomDoan wrote: ↑Thu Jan 22, 2026 9:08 am I'm not sure what it is that you think that procedure is doing, but it's not block bootstrapping. The only thing that you are reshuffling are the independently drawn random numbers, and reshuffling independent random numbers produces independent random numbers.
You shuffle the values of the trigger series, not a randomized series.
ac_1
Sorry, are you saying the fix is
set bootviol startl endl = trigger(bootentries(t))
Then, the p-value for Day 1 is completely different from the analytical Kupiec.
I'm not sure what you're asking. That's the whole point of bootstrapping---it generates an empirical distribution rather than the asymptotic.
ac_1
acKupiecBlockBoot.src:
S1. Counts actual violations in the VaR OOS sample.
S2. Computes Kupiec POF statistic as usual.
S3. Generates many synthetic violation series under H0 (correct VaR model): H0 : violation probability = alpha (correct unconditional coverage)
S4. Uses block bootstrap with blocklength = h to reproduce the clustering caused by overlapping h-day returns.
S5. Computes the Kupiec statistic for each synthetic series.
S6. Compares the real statistic to the bootstrap distribution.
It is a valid test for h-day VaR, unlike the standard Kupiec test.
Randomly rearranging (block bootstrapping) independent random variables as in your S4 does not produce correlated random variables.
Block bootstrapping is applied to (mildly) serially correlated actual data to try to maintain as much as possible of the correlation structure.
