unit root test with 2 structural breaks
Ana
Unread post by Ana »
I am struggling with my PhD and was really hoping someone would be kind enough to share with me a code for implementing unit root test with 2 structural breaks, as the one described in either "Multiple trend breaks and the unit-root hypothesis" by Lumsdaine and Papell (1997), or in "Minimum lagrange multiplier unit root test with two structural breaks" by Lee and Strazicich (2003).
I found the codes for GAUSS, but I do not have time to learn how GAUSS works as my presentation is only in a couple of weeks.
I really appreciate the help!
Ana
(The procedure originally inserted here has been revised and moved to the RATS procedures area)
Tom Doan
Estima
Ana
Hi TomDoan,
I can't thank you enough for your reply helping me alot with my work!
Ana :lol:
Jose
Doubt Lee-Strazicich Unit Root
Unread post by Jose »
Hello TomDoan!
I'm using the procedure of rats to "Lee-Strazicich Unit Root" and I have a doubt about the output. An Example:
Lee-Strazicich Unit Root Test, Series QCVEN
Regression Run From 1971:03 to 2006:04
Observations 141
Crash Model with 1 breaks
With 1 chosen from 5
Variable Coefficient Std Error
S{1} -0.0896 -2.7737
Constant 0.0062 0.9871
D(1986:04) 0.2750 4.2558
My doubt is whether the numbers in the column "Std Error" are standard errors rather than t-student statistics. This numbers are really the standards errors?
Thanks for your attention,
Anchieta
