MONTESUR.RPF uses Gibbs sampling for doing impulse responses with error bands for a near-VAR model using a standard Cholesky factorization for the contemporanenous model.
Detailed description
The use of the SUR-Gibbs procedures is described in greater detail in the Bayesian Econometrics e-course.
MONTESUR.RPF—Gibbs Sampling for near-VAR
- haversample.rat
- Data file
- (223 KiB) Downloaded 1282 times
Re: Gibbs Sampling for near-VAR
I would like to ask you which kind of prior are you using in the file montesur.rpf. I am not able to figure it out.
Adrian
Adrian
Flat on the coefficients, standard Jeffrey's prior on the covariance matrix.
Last bumped by TomDoan on Mon Oct 07, 2024 9:45 am.
