BoxJenk Instruction
BoxJenk Instruction
BoxJenk can estimate a ARIMA model and shows the coefficients. Phi(1),...Phi(p), Theta(1),...Theta(q)
Is there a embedded function to generate roots of Polynomial Phi(z)=(1-Mu1(z))(1-Mu2(z))........(1-Mu(p))
And if there are complex roots, how will rats deal with them?
Because I may need to draw analytical spectral density using Mus.
Re: BoxJenk Instruction
There is, but before you do that, you might want to look at the ARMASpectrum procedure, which directly computes the theoretical spectral density for an ARMA equation. This is an example from the Brockwell and Davis textbooks:
The functions for extracting the roots are %EQNLAGPOLY, which extracts the lag polynomial, and %POLYCXROOTS, which finds the roots of the lag polynomial. You would use them in combination as follows:
* Example 4.4.1 from pp 133-134
open data sunspots.dat
cal 1770
data 1770:1 1869:1 spots
boxjenk(ar=2,demean,maxl,method=init,define=ar2) spots
@armaspectrum(footer="Figure 4-14. Spectral Density of Sunspot Data") ar2Code: Select all
boxjenk(....,define=bjeq)
compute MAroots=%polycxroots(%eqnlagpoly(bjeq,%mvgavge))
compute ARroots=%polycxroots(%eqnlagpoly(bjeq,the dependent variable))Re: BoxJenk Instruction
For procedure @armaspectrum
Why take reciprocal again? I think previously that spectrum is calculated = sigma^2/2pi*(Phi(z)Phi(inverse(z)) (Phi is transfer func)
cset 1 =1.0/%z(t,1)Code: Select all
trfunc(...) 1
Cmult(...) 1 1
The transfer function for the ARMA equation is the FFT of the lag polynomial in the (infinite) AR representation A(L)y(t)=u(t). The estimated spectral density of y(t) is sigmau^2/|A(w)|^2. So the TRFUNC makes series 1 = A(w), the CMULT then replaces that with |A(w)|^2/sigmau^2 so you have the flip that over to get the spectral density.
Morley Nelson Zivot ReStat 2003 has a UCUR, unrestricted unobserved component model, which allows correlation between cycle error and trend error. The analytical spectrum for differenced Real GDP deltaYt is not readily availlable with @ARMASPECT. Then I consider DYt=DTrend+Dcycle, f(DYt)=1/2PI*[1, (1-L)(Phi(L)][sigmaeta^2,sigma-eta-theta|sigma-eta-theta, sigmatheta^2][1, Conjugate((1-L)(Phi(L)))]'
= sigmaeta^2/2PI + |1-L|^2|Phi(L)|^2sigmatheta^2/2PI + sigma-eta-theta/2PI*{(Phi(L)(1-L)+conjugate(Phi(L)(1-L)}
the first one is white noise spectrum, readily available.
the second one is differenced-cycle spec, If I use estimated cycle to fit AR() and use @ARMASPECTrum then mutiply by |1-L|^2 to draw this one? |1-L|^2 is equal to 2-cosine(w), how to choose w to match the @ARMAspectrum calculated part?
How about the last part? Represent it use cosine function or there is a convenient way ?
The reduced form ARMA model in that case is fairly complicated (if eta and epsilon are correlated). Instead, you'll probably find it easier to use the SSMSpectrum procedure, which computes the spectral density (matrices) for a state space model. In the MNZ paper, they're actually using the state space representation for estimation, not the reduced form ARMA model.
TomDoan wrote:The reduced form ARMA model in that case is fairly complicated (if eta and epsilon are correlated). Instead, you'll probably find it easier to use the SSMSpectrum procedure, which computes the spectral density (matrices) for a state space model. In the MNZ paper, they're actually using the state space representation for estimation, not the reduced form ARMA model.
How to define a series in terms of |1-exp(-iw)|^2?
Should I define it as 2-cosine(w) or define 1-exp(-iw) first and use cmult with its conjugate?
Assuming you mean 2-2*cos(w), you can do either. The first is clearly simpler.ivory4 wrote:
In BN decomposition, yt=a*t+PSI(1)Sum(et)+ [(PSI(L)-PSI(1))/(1-L)]et
PSI(L) Sig_e^2 is estimated from ARMA(2,2)
specturm for Difference Cycle (1-L)ct=(PSI(L)-PSI(1))et
is a*|PSI(exp(-iw)-PSI(1)|^2
a=Sig_E^2/2*PI
How to load PSI(L)-PSI(1) with TRFUNC ?
a=Sig_E^2/2*PI
When you compute the transfer function of PSI, PSI(1) is just the value at entry 1 (zero frequency). So
CSET target = %z(source,t)-%z(source,1)
will give you the FT of PSI(L)-PSI(1), where target is the frequency domain series for PSI(L)-PSI(1), and source is the frequency domain series for the transfer function of PSI.
%zlag
To use %zlag(t,x) for tranfer function in @ARMASPECTURM procedure
is equivalent to
what is wrong with the CSET part?
frequency 1 512
compute scale=0.05^2
equation(noconstant, coeffs=||1.2,-0.3,-1.4,0.5||) arma y 2 2
trfunc(equation=arma) 1
cmult(scale=2*%pi/scale) 1 1
cset 1 = 1.0/%z(t,1)
ctor 1 512/2
# 1
# abc
set freqs 1 512/2 = (t-1)*2.0/512
scatter(style=lines,hlabel="Frequency as fraction of pi")
# freqs armasp 1 512/2
frequency 1 512
cset 2 = (1-1.2*%zlag(t,1)+0.3*%zlag(t,1)*%conjg(%zlag(t,1)))/$
(1-1.4*%zlag(t,1)+0.5*%zlag(t,1)*%conjg(%zlag(t,1)))
ctor 1 512/2
# 1
# aaa
# freqs aaa 1 512/2
TomDoan wrote:When you compute the transfer function of PSI, PSI(1) is just the value at entry 1 (zero frequency). So
For example if paramets are estimated like these,
AR Coeff Ph1=1.2;Phi2=-0.3
MA Coeff Theta1=-1.4, Theta2=0.5
frequency 2 512
*PSI^-1
OR I need to get Phi DIRECTLY instead of Phi^-1 by change the input of equation(coeffs=||-Theta1,-Theta2, -Phi1, -Phi2||
Then
cset 2 = %z(1,t)-%z(1,1)
cmult(scale=2*%pi/scale) 2 2
ctor 1 512/2
# 2
# abc
Re: %zlag
First off, you're not fully using the %ZLAG function. You can simplify the whole calculation to:ivory4 wrote:To use %zlag(t,x) for tranfer function in @ARMASPECTURM procedure
cset 1 = (1-1.2*%zlag(t,1)+0.3*%zlag(t,2))/$
(1-1.4*%zlag(t,1)+0.5*%zlag(t,2))
Regarding the CSET, that's a situation in which the error message tells you exactly what the problem is.
## SR3. Tried to Use Series Number 2, Only 1 Are Available
You tried to use series number 2 when you only asked for 1. My CSET creates series 1.
What does %z return?
Manual only says that ARRAY of COMPLEX series defined by FREQUENCY, did not mention its parameter setting
See page 195 of the reference manual (under FREQUENCY).
