Scatter
ivory4
Scatter
Unread post by ivory4 »
open data sum.txt
calendar(q) 1947:1
data(format=free,org=columns) 1947:1 2009:1 lgdp
set lgdp / = 100*lgdp
compute nobs=2009:1-1949:1+1
Plot Spectrum of bkcycle
Because I need to make some changes to the graphic option, I follow the default setting in @spectrum but I did not use the .src directly
@bkfilter(nodiff) lgdp / bkcycle
set frequencies 1 256 = (t-1.0)/256
frequency 2 512
rtoc 1949:1 2009:1 1
# bkcycled
# 1
fft 1
cmult(scale=1.0/(2.0*%pi*nobs)) 1 1
window(type=flat) 1 / 2
ctor 1 256
#    2
#  bk_spect
scatter(hshade=||0.05,0.257||) 1
# frequencies bk_spect 1 256
Why the graph is scattered but not smoothed line?
Re: Scatter
You forgot the STYLE=LINES option. The default for SCATTER is disconnected symbols at the x-y points.
