QUANTILE
comac
QUANTILE
Unread post by comac »
Dear all,
In the code below I am computing some different betas (say beta1 and beta2) from bootstrapped-VAR residuals. How can I obtain quantiles for beta1 and beta2?
@VARBootSetup(model=varmodel) bootvar
compute rstart=%regstart()
compute rend  =%regend()
compute bootdraws=2000
compute nvar  =3
compute nsteps=8
dec vect[rect] beta1(bootdraws)
dec vect[rect] beta2(bootdraws)
infobox(action=define,progress,lower=1,upper=bootdraws) $
   "Bootstrap Simulations"
do draw=1,bootdraws
   @VARBootDraw(model=varmodel,resids=resids) rstart rend
   * Estimate the model with resampled data
   estimate(noprint,noftests)
   ....instructions.....
  compute beta1 = [....instructions.....]
  compute beta2 = [....instructions.....]
end do draw
infobox(action=remove)
Following the User's Guide, Chpt. 13 I have inserted in the code and hence in the loop:
dec vect[rect] sims(bootdraws)
compute sims(draw) = beta1(draw)
compute fract=%fractiles(sims,||.25,.75||)
the simulation works just fine, but then I get the following error message :
Can't Find Match for %FRACTILES(VECTOR(VECTOR),RECTANGULAR). Closest Match is %FRACTILES(MATRIX(REAL),VECTOR)
>>>>s(sims,||.25,.75||)<<<<
Does anybody know how to make them match?
Thank you,
C
Re: QUANTILE
%FRACTILES applies to only one "vector" of data at a time so you have to extract each set of bootstrapped values in turn for each of the coefficients. Do something like this:
dec rect[vect] fract(%rows(beta1),%cols(beta1))
dec vect onevect(bootdraws)
dec integer k
do i=1,%rows(beta1)
   do j=1,%cols(beta1)
      ewise onevect(k)=sims(k)(i,j)
      compute fract(i,j)=%fractiles(onevect,||.25,.75||)
That will give you an N x K set of two vectors with the .25 and .75 percentiles for each coefficient.
comac
Re: QUANTILE
Tom -- this is helpful. However i get the following error message:
## SX11. Identifier K is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>> ewise onevect(k)<<<<
How could I help it?
Thank you,
C.
Re: QUANTILE
Just add
dec integer k
I've fixed the post above.
comac
Re: QUANTILE
Tom -- sorry for bothering.
The code needs 'sims' to be declared itself. I added to your code. The program does not crash but in the output below there is obviously something wrong.
dec integer k
compute sims(draw) = betauip(draw)
do i=1,%rows(beta1)
   do j=1,%cols(beta1)
-0.63567 -0.22892 NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA
NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA
To simplify things, I would be happy if I could get quantiles of the whole distribution (and not coefficient by coefficient). Is there some way? Are the two coefficients overthere those for the whole distribution of beta1?
Thank you again.
Re: QUANTILE
Since sims was supposed to be the source for the simulations, the fact that it isn't defined would be a major problem in computing the percentiles of the simulations. Your loop should actually read:
  compute beta1(draw) = [....instructions.....]
  compute beta2(draw) = [....instructions.....]
I assumed because of the way you wrote it that beta1 and beta2 were representatives of what you wanted to save, rather than the actual storage of the bootstrap draws. (It's usually better to include the complete set of instructions rather than trying to paraphrase).
So where I said sims, you actually want beta1 (and beta2 in a separate loop) and where I said %rows(beta1) and %cols(beta1) you want the rows and columns of whatever you were saving.
comac
Re: QUANTILE
Tom -- thank you! Still, I am a bit confused.
I am saving beta1 as I want a distribution for that, and consequently fractiles for its distribtuion.
Following your hint I've substituted 'sims' with 'beta1' in the inside-loop.
compute bootdraws=100
compute nvar  =5
compute nsteps=8
dec integer k
do draw=1,bootdraws
   estimate(noprint,noftests) rstart rend
  [...instructions.....]	*
   do i=1,%rows(beta1)
   do j=1,%cols(beta1)
   ewise onevect(k)=beta1(k)(i,j)
      compute fract(i,j)=%fractiles(onevect,||.025,.975||)
 infobox(current=draw)
end do draw
dis fract
The results are just fine for fractile(1,1).
The problem is that (as before) the quantiles other than the one in (1,1) are not defined. As the code is writte, I guess those in (1,1) are quantiles for the whole distribution of beta1.Isn't it?
-1.61601 1.41303 NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA
Thank you for your patience,
C.
Re: QUANTILE
You have to move the calculation of the quantiles outside the loop. So the loop should look like:
do draw=1,bootdraws
end do draw
The dimensions of FRACT need to be the dimensions of what you're saving in beta1, not beta1 itself. (beta1 is the storage for the set of draws). I'm guessing that the columns are nvar and I'll call the rows # of regressors. So the post-loop processing is:
dec rect[vect] fract(# of regressors,nvar)
dec integer k
do i=1,# of regressors
   do j=1,nvar
dis fract
comac
Re: QUANTILE
I am sorry. Probably I was completely unclear about it.
Beta1 is computed as a scalar and beta1 in the loop collects them all.
Hence, I am setting fract(1,1), right?
If it is so, the code works just perfectly. Many thanks.
dec rect[vect] fract(1,1)
dec integer k
do i=1,1
   do j=1,1
dis fract
Re: QUANTILE
If you're collecting a scalar, then that would be correct.
