VAR Heteroskedasticity-consistent standard errors
comac
Dear all,
is there some code for computing heteroskedasticity-consistent standard errors for a VAR system?
Thanks in advance,
C.
Thanks in advance,
C.
Re: VAR Hetreskodasticity-consistent standard errors
Use SUR with the ROBUSTERRORS option as is shown below:
system(model=varmodel)
variables dinv dinc dcons
lags 1 2
estimate(sigma,resids=resids)
sur(model=varmodel,robust)-
ying2728
Re: VAR Heteroskedasticity-consistent standard errors
In the following SUR:
lags 1 2
If each equation uses different different indep var: e.g.,
dinv = constant dinv(-1)
dinc = constant dinc(-1)
dcons = constant dcons(-1)
How can I do it? Thanks.
lags 1 2
Isn't that what SUR.RPF does? In general, SUR is used when the equations aren't the same.
