how can i make shadow more dark than it before
xiangyu71
set raterise = t>=2007:8.and.t<=2008:1.or.t>=2008:9.and.t<=2008:12
grahpy(shading=raterise....................................
when i print it ,it almost can not discern.
whether can i make shadow more dark than it before or not?
thanks very much!
best regards!
thanks very much!
best regards!
Re: how can i make shadow more dark than it before
Create a file (I'm calling it darker.txt) with the line
FILL_BW_0=0,.8
In the RATS program, before you do your graph, add the following:
The default level of gray for the shading is .9. The gray scale runs from 0.0=black to 1.0=white. You can experiment with numbers around .8 to see what works best with your printer. (You can often see quite a difference with even very small differences in the gray scale value because printers often are poor at delivering accurate light gray levels).
FILL_BW_0=0,.8
open styles darker.txt
grparm(import=styles)-
xiangyu71
