Both dynamic and static forecast?
luching
In a VAR system, is there any inbuilt command or a quick way to do a dynamic forecast for some equations and static forecast for the rest of the equations?
Re: Both dynamic and static forecast?
If you want to do a dynamic forecast for some variables, while using the actual values for the others, you just need to define a model which includes only the equations (from the VAR) defining the variables that you want to treat dynamically. In other words, you "exogenize" some subset of the variables.
luching
Here's what I have done:
group smodel %modeleqn(varmodel,1) %modeleqn(varmodel,2)
forecast(model=smodel)
I think the issue is that when I try to forecast the smaller model, it cannot read the 3rd variable which is the one I want to use as actuals.
It's something else. It can't even run this:
group smodel %modeleqn(varmodel,1) %modeleqn(varmodel,2) %modeleqn(varmodel,3)
Use the following as a workaround:luching wrote:Here's what I have done:
modify %modeleqn(varmodel,1) eqn1
modify %modeleqn(varmodel,2) eqn2
group smodel eqn1 eqn2
forecast(model=smodel)-
luching
Thanks. This is a lot more elegant than the one I wrote using matrices.
