Check stationarity of VAR
dennis0125hk
I would like to implement a code to check whether the VAR is stationary or not. Given the VAR,
A(L)y_t = e_t
If the VAR is stationary, then det(A(z)) = 0 has all roots that lie outside unit circle. However, if one of the roots lies inside the unit circel, then the VAR is said to be non-stationary. I would like to implement a code to check the stationarity according to the rule.
The equation involves determinant of matrix which depends on z. I think of using %det to implement the code. However, the matrix considered depends on z, so it involves other commands as well. Is there any short command to implement this? Or I need to consider some other kinds of numerical methods to solve the problem?
Thanks for attention. I would be pleased if anyone can help me about this.
A(L)y_t = e_t
Re: Check stationarity of VAR
Check out kpsw1.prg in the King, Plosser, Stock, Watson AER 1991 replication. It uses
eigen(cvalues=cvt) %modelcompanion(v3)
to get the eigenvalues of the companion matrix for the model, which is the set of roots (actually reciprocals of the roots) that you want.
apollon
It's good to know that RATS allows for that, though it would be great if there was a dedicated function for this.
dennis0125hk were you able to draft your function ?
The problem you have is that the working definition of "stationary" can vary from situation to situation. Due to the possibility of roundoff error, a hard cut-off of 1.0 isn't a good idea. The typical cutoff choice is around .99 or .999, such as the following:
The following will return the absolute value of the dominant root of a model, which you can then test as you need.
compute testroot=%modelcompanion(qualvar)
eigen(cvalues=cv) testroot
if %cabs(cv(1))>.999 {
disp "VAR draw rejected"
goto redraw
}Code: Select all
function %ModelLargestRoot model
type model model
local vect[complex] cv
eigen(cvalues=cv) %modelcompanion(model)
compute %ModelLargestRoot=%cabs(cv(1))
end-
apollon
Thanks so much for your promt reply. That would seem to be what I'm looking for.
I couldn't find kpsw1.prg anywhere though, can you pls advise ?
It's in one of the paper replication folders: KPSW AER 1991
apollon
I got this now. Can you pls advise how to incorporate the two pieces of code you wrote into KPSW1.PRG ?
I tried by copying and pasting the first by changing model to v3 and I didn't see any output.
The second was giving me the error that "CV is not a PROCEDURE/FUNCTION Parameter". I then took it out
and pasted this line under your code: %ModelLargestRoot v3. I am now getting "Expected Instruction Here".
Sorry. I corrected the function above - it should have been local ... cv, not type ... cv
You would use it as follows (regarding the earlier test)
if %ModelLargestRoot(qualvar)>.999 {
goto redraw
goto redraw
apollon
It still doesn't produce any output. Below is my modified var_1_2.prg:
type model model
open data e1.dat
calendar(q) 1960
data(format=prn,org=columns,skips=6) 1960:01 1982:04 invest income cons
set dinc = log(income/income{1})
set dcons = log(cons/cons{1})
set dinv = log(invest/invest{1})
system(model=varmodel)
variables dinv dinc dcons
lags 1 2
estimate(resids=unresids) * 1978:4
if %ModelLargestRoot(varmodel)>.001 {
goto redraw
dis %ModelLargestRoot(varmodel)-
Your function is working fine; you're just taking code out of a more complicated procedure which, for instance, has a "redraw" label. Just get rid of your faulty
goto redraw
and just leave the DISPLAY instruction at the end, and you'll see that it works correctly.
goto redraw
