density function coding
sam2010
Good day,
You help is needed to solve this coding problem. In my estimation stage I need to code a dummy variable (d) with 1 if the sign of the variable is positive and 0 otherwise. The defined density function has two parts and the initial code is:
frml xxx = %sign(dy)
frml if xxx > 0.0 {
xx = 1.0
else {
xx = 0.0
frml d = ((xxx)^2.0-xxx)/(1.0 + %abs(xxx))
frml k = log( 4/(sigma1*(1-(%sign(lamda1)*(%betainc(a1,1/alpha1,1/alpha1)))) )
frml h1 = 0.5*(1+%sign(lamda1)*(%gammainc((%abs(a1/(2^0.5)))^alpha1,1/alpha1)))
frml h2 = 0.5*(1+%sign(lamda2)*(%gammainc((%abs(a2/(2^0.5)))^alpha2,1/alpha2)))
frml p11 = alpha1/(2*(2^0.5)*(%gamma(1/alpha1)))
frml p12 = -(%abs(y/((2^0.5)*sigma1)))^alpha1
frml logl = (k + log(p11)+ log(h1))*d + (k + log(p12) + log(h2) )*(1-d)
nonlin a1 a2 alpha1 alpha2 sigma1 sigma2 lamda1 lamda2
maximize(pmethod=simplex,piters=5,method=bfgs,trace,iters=200) logl start+1 end
Thanks for your help.
Sam
frml if xxx > 0.0 {
xx = 1.0
else {
xx = 0.0
Sam
Re: density function coding
Isn't dy just data? If it is, then you don't need a FRML for xxx; you can just stick with
set xxx = (dy>0)
There's clearly something amiss with the rest of your formulas, though, since lamda1 and lamda2 only enter in %sign(...) functions, so only their signs are determined.
set xxx = (dy>0)
sam2010
Thanks Tom for you reply.
Yes dy is just data series. What I originally have for lamda is rather: lamda/%abs(lamda) which is coded as %sign(lamda). I'll recode it as: lamda/%abs(lamda).
sam2010
One more question:
How can we deal with formulas that include the absolute value of variable with power (another coef) and frml with %abs :
dec real a1 a2 alpha1 alpha2 sigma1 sigma2 lamda1 lamda2
compute alpha1 = 2.0
compute alpha2 = 2.0
compute sigma1 = sqrt(dyvar)
compute sigma2 =sqrt(dyvar)
compute lamda1 = -0.0001
compute lamda2 = -0.0001
compute a1 = ((%abs(lamda1))^alpha1)/(1.0+((%abs(lamda1))^alpha1))
compute a2 = ((%abs(lamda2))^alpha2)/(1.0+((%abs(lamda2))^alpha2))
and
frml k = log( 4/(sigma1*(1-((lamda1/%abs(lamda1))*(%betainc(a1,1/alpha1,1/alpha1)))) )
or should I just code it as:
where %sign(lamda) is replacing lamda1/%abs(lamda1)
Thanks for you help.
Sam
One more question:
and
Sam
By all means use the %SIGN function. I was just pointing out that in what you had posted, only the signs of lamda1 and lamda2 would matter. This new one shows that they also enter more generally.
sam2010
Thanks Tom,
I used both %sign and %abs and none seems to work with my code:
In,
I got the error:
Can't Interpret MATRIX(REAL) ** or ^ REAL
>>>>bs(lamda1))^alpha1)<<<<
Thnks
In,
I got the error:
Thnks
sam2010
Hi again,
I also tried to use the log exp way to remove the real power but exp(%abs(lamda1)) or log(%abs(lamda1)) is not working with rats:
compute a1 = (log(exp(alpha1*(%abs(lamda1))))) /(1.0+( log(exp(alpah1*(%abs(lamda1))))))
the error:
Can't Find Match for EXP(MATRIX(REAL)). Closest Match is EXP(REAL)
>>>>ha1*(%abs(lamda1)))<<<<
Any help please,
Sam
the error:
Any help please,
Sam
Use just abs(...), not %abs(...) for scalars. abs is one of a handful of common functions which don't use the % prefix. %abs is for element-by-element absolute value for a matrix.sam2010 wrote:Thanks Tom,
In,
I got the error:
Thnks
sam2010
Thanks Tom for your kind help.
Sam
Sam
