Creating shading series
John_Val
I have 2 series hist and RSI from time 10 to 257. I want to create a dummy variable shade that is equal to 1 if hist(t)<0 and hist(t-1)>0 and RSI(t)>=60
It is also equal to 1 if hist(t)<0 and hist(t-1)>0 and RSI(t-1) >=60. When I run the program nothing gets recorded. I presume I did not set up correctly the if-block ****
Could you correct what I wrote.
do t=10,257
if hist(t)<0 {
if hist(t-1)>0 {
if RSI(t) >=60 {
com shade(t)=1.0
****** if RSI(t-1) >=60 {
com shade(t) = 1.0
else {
com shade(t)=0
end do t
do t=10,257
if hist(t)<0 {
if hist(t-1)>0 {
if RSI(t) >=60 {
com shade(t)=1.0
com shade(t) = 1.0
else {
com shade(t)=0
end do t
Re: General Question
First, you appear to be commenting out the first line of the second IF clause for RSI, but not the rest. When you want to disable some lines, it's a good idea to use the Edit-Comment Out Lines operation; then you can later do Edit-Uncomment Lines to enable them again.
It's usually better to create a dummy like this using SET with relational operators. In this case, it would be
set shade 10 257 = hist<0.and.hist{1}>0.and.(rsi>=60.or.rst{1}>=60)
John_Val
hi,
I placed ***** to show where I think the the problem is. In the program I don't have any *****.
For example, in the below program I want comput1 to occur if the first two if statements are true, while compute2 occurs if the first and third if statements are true.
Did I set up the code correctly. Does Winrats know that for the comput2 to be done the first and third if statments have to be true.
I know I can set it up much easier using set command in order to create the dummy variable, but I want to better understand the programming capabilities in the case more complex calculations come up.
if { ...
if { ...
comput1 ....
if { ....
comput2...
if { ...
if { ...
comput1 ....
if { ....
comput2...
With proper indenting, your loop looks like this:
It looks as if you'll get the 1's where you want them, but not the 0's, since the shade(t)=0 will only get executed if hist(t)>0. There's no way to write that logic to get the 1's and 0's without a single long clause (as done in my SET instruction). However, the way to handle that is to set everything to 0 first, then set the 1's. That is:
do t=10,257
if hist(t)<0 {
if hist(t-1)>0 {
if RSI(t) >=60 {
com shade(t)=1.0
if RSI(t-1) >=60 {
com shade(t) = 1.0
else {
com shade(t)=0
end do tCode: Select all
do t=10,257
com shade(t)=0
if hist(t)<0 {
if hist(t-1)>0 {
if RSI(t) >=60 {
com shade(t)=1.0
if RSI(t-1) >=60 {
com shade(t) = 1.0
end do it
