how to select mean equation in MVgarch model?
hardmann
Dear Tom:
sorry. I know how to specify mean equation in Mvgarch.
but I do not know how to select mean equation. eg, Under what circumstances, to choose var, or arma.
thanks again
Thank you.
Sorry, I become a king of question.
Hardmann
thanks again
Thank you.
Hardmann
moderator
- Site Admin
Re: how to specify mean equation in MVgarch model?
We cover this in some detail in the RATS User's Guide. For example, if you have version 8, see Section 9.8.1 ("The Mean Model").
The key point is to define your mean model as a MODEL object, and then use the MODEL option on GARCH. There's an example in the User's Guide section noted above demonstrating the setup for a VAR model.
Tom Maycock
Tom Maycock
Start small (just means) and check your diagnostics for serial correlation in the standardized residuals. There is no "rule".hardmann wrote:Dear Tom:
How to specify mean equation in MVgarch model, var or arma? what is rule?
Thank you.
Hardmann
hardmann
Re: how to select mean equation in MVgarch model?
thanks again.
hardmann
thanks again.
hardmann
