Forecasting with VAR
kariopaul
Unread post by kariopaul »
Can some please help me to get confidence intervals for VAR forecasts.
a_bar
Re: Forecasting with VAR
Unread post by a_bar »
I believe that the montevar.src procedure can be used to generate confidence bands for the in-sample series of a fitted VAR-X model, but can this same procedure be used to generate confidence bands for the out-sample forecasted series?
I'm not too experienced with multivariate time-series, so as a quick solution I've made the assumption that my forecasted series are normally distributed and topped them up with 1.96*(the standard error of the ESTIMATED series) for 95% confidence bands. Does anyone else have a link to any other quick but possibly more 'acceptable' heuristics to form these confidence bands?
The error bands for forecasts are relatively simple if you act as if the estimated coefficients are known rather than subject to sampling error. FORECAST with the STDERRS option takes care of most of the work. A couple of fairly simple examples are the Lutkepohl textbook example lutkp098.rpf and the Tsay textbook example tsayp407.rpf.
If you would like to take the uncertainty in the coefficients into account, there are, as with error bands for impulse responses, three basic ways to handle it: by Monte Carlo simulation methods, bootstrapping and the delta method. I don't have any examples applying the last two methods to forecasting. Bootstrapping requires a relatively simple change to a bootstrapping loop for impulse responses. The delta method is quite a bit harder--Lutkepohl derives the formula for the forecast variance in his book but doesn't have an application.
The following is an example of simulation methods, applied to a BVAR. This is an example from the Bayesian Econometrics e-course. See http://www.estima.com/courses_completed.shtml for details.
* Bayesian Econometrics Workbook, Example 6.8
* Gibbs sampling on a Bayesian VAR with a "Minnesota" prior
compute lags=4			;*Number of lags
compute nstep=16		;*Number of response steps
compute nburn=500   	;*Number of burn-in draws
compute ndraws=2500	;*Number of keeper draws
open data haversample.rat
cal(q) 1959
data(format=rats) 1959:1 2006:4 ftb3 gdph ih cbhm
set loggdp = log(gdph)
set loginv = log(ih)
set logc   = log(cbhm)
* These are the controlling parameters for the symmetric "Minnesota"
* prior - the own lag tightness and the relative tightness on the other
* lags.
compute tight=.1
compute other=.5
* First, estimate the system with a prior via mixed estimation, to see if
* we come up with something similar via Gibbs sampling.
system(model=varmodel)
variables loggdp loginv logc ftb3
lags 1 to lags
specify(type=symmetric,tight=tight) other
* Estimate with a prior
estimate
compute nvar=%nvar
source bvarbuildprior.src
@BVARBuildPriorMN(model=varmodel,tight=.1,other=.5) hbpriors hpriors
@BVARFinishPrior hbpriors hpriors bprior hprior
compute sigmad=%sigma
dec vect[series] forecast(nvar)
dec vect[series] forestderr(nvar)
* Range to forecast
compute fstart=%regend()+1
compute fend  =fstart+nstep-1
dec series[rect] forecasts
gset forecasts fstart fend = %zeros(nvar,ndraws)
infobox(action=define,progress,lower=-nburn,upper=ndraws) "Gibbs Sampler"
do draw=-nburn,ndraws
   infobox(current=draw)
   * Draw b given sigma
   compute bdraw =%ranmvkroncmom(%cmom,inv(sigmad),hprior,bprior)
   compute rssmat=%sigmacmom(%cmom,bdraw)
   * Draw sigma given b
   compute sigmad=%ranwisharti(%decomp(inv(rssmat)),%nobs)
   if draw<=0
      next
   compute %modelsetcoeffs(varmodel,bdraw)
   simulate(model=varmodel,cv=sigmad,results=simresults,steps=nstep)
   gset forecasts fstart fend = %psubmat(forecasts(t),1,draw,%xt(simresults,t))
end do draw
infobox(action=remove)
dec vect[series] faninput(7)
do i=1,7
   set faninput(i) fstart fend = 0.0
dec vect fjt percent
do j=1,nvar
   do time=fstart,fend
      compute fjt=%xrow(forecasts(time),j)
      compute percent=%fractiles(fjt,||.005,.05,.25,.50,.75,.95,.995||)
      compute %pt(faninput,time,percent)
   end do time
   graph(style=line,overlay=fan,ovcount=6,ovsame,$
      header="Forecasts of "+%l(%modeldepvars(varmodel)(j))) 7
   # faninput(4)
   # faninput(1)
   # faninput(2)
   # faninput(3)
   # faninput(5)
   # faninput(6)
   # faninput(7)
