Value-at-Risk Forecasts with AR(1)-GARCH(1,1)
Hi again,
I need to generate and test Value-at-Risk (VaR) forecasts based on AR(1)-GARCH(1,1) estimates. Could you please suggest me any references (RATS codes) which deal with VaR forecasts in GARCH setup?
Thanks in advance,
Farid
Thanks in advance,
Farid
Re: Value-at-Risk Forecasts with AR(1)-GARCH(1,1)
The Tsay textbook has about five examples on calculation of VaR using GARCH models. This is the closest to what you need. You use UFORECAST to compute the mean and the @GarchFore procedure to compute the variance.
* Tsay, Analysis of Financial Time Series, 3rd edition
* Example 7.3 (continued) from page 338
* Value at Risk calculation
open data d-ibmln98.dat
data(format=free,org=columns) 1 9190 ibmlog
set ibmlog = .01*ibmlog
* Define the equation for the mean
equation ar2 ibmlog
# constant ibmlog{2}
* GARCH with normal residuals
garch(p=1,q=1,equation=ar2,hseries=h,resids=res)
* Forecast the variance using @GARCHFORE and the series itself using
* UFORECAST.
@garchfore(steps=15) h res
uforecast(equation=ar2,steps=15) fret
* Use SSTATS to accumulate the mean and variance over the forecast period.
sstats 9191 9205 fret>>ret15 h>>ret15h
disp "5% VaR, 15 day horizon on 10000000" -10000000*(ret15+%invnormal(.05)*sqrt(ret15h))- Attachments
- d-ibmln98.dat
- Data file
- (80.77 KiB) Downloaded 739 times
Thanks for response Tom. In my case, however, I have a little bit different situation. I have a full sample of 1287 days. I use 511 days as a sample period to estimate AR(1)-GARCH(1,1) coefficients. After that I roll the regressions with moving window of 511 to obtain AR(1)-GARCH(1,1) coefficients for the following 777 days (forecasting period).
Here is the code for what I've done so far:
After that, according to the reference you gave, I should have the following:
Does it make sense?
Contrary to that I have found one code from my professor, which is not complete though. Thus I cannot follow it properly. It's completely different from Tsay code and that confuses me.
Here it is:
OPEN DATA "C:\Documents and Settings\admin\Desktop\teze.RAT"
CALENDAR(D) 2006:1:3
DATA(FORMAT=RATS) 2006:01:03 2010:12:08 RT
smpl 2 511
garch(p=1,q=1,reg,resids=u,hseries=h) / rt
# constant rt{1}
***Testing standardized residuals
set ustd = u/sqrt(h)
set ustdsq = ustd^2
correlate(qstat,number=40,dfc=1,title="LB Test") ustd
correlate(qstat,number=40,dfc=2,title="McLeod-Li Test") ustdsq
stats ustd
***Rolling GARCH
compute width=511
dec vect[series] coeffs(5)
do gend=width,1287
if gend==width
garch(p=1,q=1,reg,resids=u,hseries=h,noprint) gend-width+2 gend rt
# constant rt{1}
else
garch(p=1,q=1,reg,resids=u,hseries=h,initial=%beta,hessian=%xx,noprint) gend-width+2 gend rt
# constant rt{1}
compute %pt(coeffs,gend,%beta)
end do gend
garch(p=1,q=1,equation=ar1,hseries=h,resids=u)
* UFORECAST.
@garchfore(steps=777) h u
uforecast(equation=ar1,steps=777) fret
sstats 512 1287 fret>>ret1 h>>ret1h
disp "5% VaR, 1 day horizon on 10000000" -10000000*(ret1+%invnormal(.05)*sqrt(ret1h))
*Contrary to that I have found one code from my professor, which is not complete though. Thus I cannot follow it properly. It's completely different from Tsay code and that confuses me.
Here it is:
nonlin(parmset=garchparms) vc=.1 va=.84 vb=.14
frml resid = x1
frml hf = vc + va*h{1} + vb*u{1}**2
frml logl = (h(t)=%ovcheck(hf(t))),(u(t)=resid(t)),-.5*(log(h)+u**2/h)
linreg(noprint) x1 / u
# constant
compute vc=.5,va=.7,vb=.2
set h = %seesq
maximize(parmset=garchparms,method=bfgs,robusterrors,iters=10,noprint) logl gstart gend
set ce = u/sqrt(h)
order ce secondt lastt
compute perc1=secondt+40
compute perc5=secondt+200
compute perc95=secondt+3800
compute perc99=secondt+3960
compute s_cband1=ce(perc1)
compute s_cband5=ce(perc5)
compute s_cband95=ce(perc95)
compute s_cband99=ce(perc99)
do tim0=4000,7999
compute tim1=tim0+1
compute ht(4000)=h(4000)
compute ut(tim0)=x1(tim0)
compute ht(tim1)= vc + va*ht(tim0) + vb*ut(tim0)**2
compute obser5=s_cband5*sqrt(ht(tim1))
compute obser95=s_cband95*sqrt(ht(tim1))
compute obser1=s_cband1*sqrt(ht(tim1))
compute obser99=s_cband99*sqrt(ht(tim1))
compute s_cp5(tim1)=obser5
compute s_cp95(tim1)=obser95
compute s_cp1(tim1)=obser1
compute s_cp99(tim1)=obser99
compute n_vio(tim1)=%if(s_cp5(tim1)<=x1(tim1).and.x1(tim1)<=s_cp95(tim1),0,1)
if n_vio(tim1)=1.and.x1(tim1)<s_cp5(tim1)
compute d_vio=s_cp5(tim1)-x1(tim1)
else if n_vio(tim1)=1.and.x1(tim1)>s_cp95(tim1)
compute d_vio=x1(tim1)-s_cp95(tim1)
else
compute d_vio=%NA
compute cdeg_vio(tim1)=d_vio
if n_vio(tim1)=1.and.x1(tim1)<s_cp5(tim1) {
compute l_vio=s_cp5(tim1)-x1(tim1),u_vio=%NA
else if n_vio(tim1)=1.and.x1(tim1)>s_cp95(tim1) {
compute u_vio=x1(tim1)-s_cp95(tim1),l_vio=%NA
else {
compute u_vio=%NA,l_vio=%NA
compute l_cdeg_vio(tim1)=l_vio,u_cdeg_vio(tim1)=u_vio
if l_cdeg_vio(tim0)!=%NA.and.l_cdeg_vio(tim1)!=%NA
compute lc_consec(tim1)=1
else
compute lc_consec(tim1)=%NA
if u_cdeg_vio(tim0)!=%NA.and.u_cdeg_vio(tim1)!=%NA
compute uc_consec(tim1)=1
else
compute uc_consec(tim1)=%NA
compute zn_vio(tim1)=%if(s_cp1(tim1)<=x1(tim1).and.x1(tim1)<=s_cp99(tim1),0,1)
if zn_vio(tim1)=1.and.x1(tim1)<s_cp1(tim1)
compute d_vio=s_cp1(tim1)-x1(tim1)
else if zn_vio(tim1)=1.and.x1(tim1)>s_cp99(tim1)
compute d_vio=x1(tim1)-s_cp99(tim1)
else
compute d_vio=%NA
compute czdeg_vio(tim1)=d_vio
if zn_vio(tim1)=1.and.x1(tim1)<s_cp1(tim1) {
compute zl_vio=s_cp1(tim1)-x1(tim1),zu_vio=%NA
else if zn_vio(tim1)=1.and.x1(tim1)>s_cp99(tim1) {
compute zu_vio=x1(tim1)-s_cp99(tim1),zl_vio=%NA
else {
compute zu_vio=%NA,zl_vio=%NA
compute zl_cdeg_vio(tim1)=zl_vio,zu_cdeg_vio(tim1)=zu_vio
end do tim0
statistics(noprint) ht 4001 8000
compute c_var(k)=sqrt(%variance),c_mvar(k)=%mean
statistics(noprint) s_cp1 4001 8000
compute c_var1(k)= %mean
statistics(noprint) s_cp5 4001 8000
compute c_var5(k)= %mean
statistics(noprint) s_cp95 4001 8000
compute c_var95(k)=%mean
statistics(noprint) s_cp99 4001 8000
compute c_var99(k)=%mean
statistics(noprint) lc_consec 4001 8000
compute nlc_consec(k)=%nobs
statistics(noprint) uc_consec 4001 8000
compute nuc_consec(k)=%nobs
statistics(noprint) czdeg_vio 4001 8000
compute czc_vio(k)=%nobs
compute czt_deg_vio(k)=%mean
statistics(noprint) zl_cdeg_vio 4001 8000
compute zlcc_vio(k)=%nobs
compute zlct_deg_vio(k)=%mean
statistics(noprint) zu_cdeg_vio 4001 8000
compute zucc_vio(k)=%nobs
compute zuct_deg_vio(k)=%mean
statistics(noprint) cdeg_vio 4001 8000
compute cc_vio(k)=%nobs
compute ct_deg_vio(k)=%mean
statistics(noprint) l_cdeg_vio 4001 8000
compute lcc_vio(k)=%nobs
compute lct_deg_vio(k)=%mean
statistics(noprint) u_cdeg_vio 4001 8000
compute ucc_vio(k)=%nobs
compute uct_deg_vio(k)=%mean
compute ccoff0(k)=vc,ccoff1(k)=va, ccoff2(k)=vb
compute cband5(k)=s_cband5,cband95(k)=s_cband95,cband1(k)=s_cband1,cband99(k)=s_cband99
My previous AR(1)-GARCH(1,1) rolling has already forecasted 1) h series 2) u series 3) 5 coefficients for 777 days.
Now I need to do the following:
specify mean equation, variance equation and calculate one day ahead VaR forecasts for further testing (comparing to real returns).
When I specify mean and variance equations I cannot input coefficients into variance model.
I think the following code should be appropriate for one-day ahead VaR forecasts:
But it's not. It doesn't recognize coefficients as values from previous forecasting and gives an error: "## SX22. Expected Type REAL, Got MATRIX[REAL] Instead
>>>>ffs(4)*ut(tim0)**2<<<<".
Could you please look through this code and help me out?
Thanks in advance
set ht 1 1287 = 0.0
set ut 1 1287 = 0.0
DO lastt = 511,1287
compute lastt2=lastt+1
compute lastt1=lastt-1
compute firstt = lastt-776
compute secondt = firstt+1
compute zerot = firstt-1
set ce = u/sqrt(h)
compute perc1=secondt+7
compute perc5=secondt+38
compute perc95=secondt+738
compute perc99=secondt+769
do tim0=511,1287
compute tim1=tim0+1
compute ht(511)=h(511)
compute ut(tim0)=rt(tim0)
compute ht(tim1)= coeffs(3) + coeffs(5)*ht(tim0) + coeffs(4)*ut(tim0)**2
Thanks in advance
This part is computing the empirical 1%, 5%, 95% and 99%-iles of the standardized residuals. (This is a rather clumsy way to do this---STATS(FRACTILES) CE rather than the ORDER instruction will compute and defined %FRACT01, %FRACT05, %FRACT95 and %FRACT99).Farid wrote:Contrary to that I have found one code from my professor, which is not complete though. Thus I cannot follow it properly. It's completely different from Tsay code and that confuses me.
Here it is:
nonlin(parmset=garchparms) vc=.1 va=.84 vb=.14 frml resid = x1 frml hf = vc + va*h{1} + vb*u{1}**2 frml logl = (h(t)=%ovcheck(hf(t))),(u(t)=resid(t)),-.5*(log(h)+u**2/h) linreg(noprint) x1 / u # constant compute vc=.5,va=.7,vb=.2 set h = %seesq maximize(parmset=garchparms,method=bfgs,robusterrors,iters=10,noprint) logl gstart gend set ce = u/sqrt(h) order ce secondt lastt compute perc1=secondt+40 compute perc5=secondt+200 compute perc95=secondt+3800 compute perc99=secondt+3960 compute s_cband1=ce(perc1) compute s_cband5=ce(perc5) compute s_cband95=ce(perc95) compute s_cband99=ce(perc99) do tim0=4000,7999 compute tim1=tim0+1 compute ht(4000)=h(4000) compute ut(tim0)=x1(tim0) compute ht(tim1)= vc + va*ht(tim0) + vb*ut(tim0)**2 compute obser5=s_cband5*sqrt(ht(tim1)) compute obser95=s_cband95*sqrt(ht(tim1)) compute obser1=s_cband1*sqrt(ht(tim1)) compute obser99=s_cband99*sqrt(ht(tim1)) compute s_cp5(tim1)=obser5 compute s_cp95(tim1)=obser95 compute s_cp1(tim1)=obser1 compute s_cp99(tim1)=obser99 compute n_vio(tim1)=%if(s_cp5(tim1)<=x1(tim1).and.x1(tim1)<=s_cp95(tim1),0,1) if n_vio(tim1)=1.and.x1(tim1)<s_cp5(tim1) compute d_vio=s_cp5(tim1)-x1(tim1) else if n_vio(tim1)=1.and.x1(tim1)>s_cp95(tim1) compute d_vio=x1(tim1)-s_cp95(tim1) else compute d_vio=%NA compute cdeg_vio(tim1)=d_vio compute n_vio(tim1)=%if(s_cp5(tim1)<=x1(tim1).and.x1(tim1)<=s_cp95(tim1),0,1) if n_vio(tim1)=1.and.x1(tim1)<s_cp5(tim1) { compute l_vio=s_cp5(tim1)-x1(tim1),u_vio=%NA } else if n_vio(tim1)=1.and.x1(tim1)>s_cp95(tim1) { compute u_vio=x1(tim1)-s_cp95(tim1),l_vio=%NA } else { compute u_vio=%NA,l_vio=%NA } compute l_cdeg_vio(tim1)=l_vio,u_cdeg_vio(tim1)=u_vio if l_cdeg_vio(tim0)!=%NA.and.l_cdeg_vio(tim1)!=%NA compute lc_consec(tim1)=1 else compute lc_consec(tim1)=%NA if u_cdeg_vio(tim0)!=%NA.and.u_cdeg_vio(tim1)!=%NA compute uc_consec(tim1)=1 else compute uc_consec(tim1)=%NA compute zn_vio(tim1)=%if(s_cp1(tim1)<=x1(tim1).and.x1(tim1)<=s_cp99(tim1),0,1) if zn_vio(tim1)=1.and.x1(tim1)<s_cp1(tim1) compute d_vio=s_cp1(tim1)-x1(tim1) else if zn_vio(tim1)=1.and.x1(tim1)>s_cp99(tim1) compute d_vio=x1(tim1)-s_cp99(tim1) else compute d_vio=%NA compute czdeg_vio(tim1)=d_vio compute zn_vio(tim1)=%if(s_cp1(tim1)<=x1(tim1).and.x1(tim1)<=s_cp99(tim1),0,1) if zn_vio(tim1)=1.and.x1(tim1)<s_cp1(tim1) { compute zl_vio=s_cp1(tim1)-x1(tim1),zu_vio=%NA } else if zn_vio(tim1)=1.and.x1(tim1)>s_cp99(tim1) { compute zu_vio=x1(tim1)-s_cp99(tim1),zl_vio=%NA } else { compute zu_vio=%NA,zl_vio=%NA } compute zl_cdeg_vio(tim1)=zl_vio,zu_cdeg_vio(tim1)=zu_vio end do tim0 statistics(noprint) ht 4001 8000 compute c_var(k)=sqrt(%variance),c_mvar(k)=%mean statistics(noprint) s_cp1 4001 8000 compute c_var1(k)= %mean statistics(noprint) s_cp5 4001 8000 compute c_var5(k)= %mean statistics(noprint) s_cp95 4001 8000 compute c_var95(k)=%mean statistics(noprint) s_cp99 4001 8000 compute c_var99(k)=%mean statistics(noprint) lc_consec 4001 8000 compute nlc_consec(k)=%nobs statistics(noprint) uc_consec 4001 8000 compute nuc_consec(k)=%nobs statistics(noprint) czdeg_vio 4001 8000 compute czc_vio(k)=%nobs compute czt_deg_vio(k)=%mean statistics(noprint) zl_cdeg_vio 4001 8000 compute zlcc_vio(k)=%nobs compute zlct_deg_vio(k)=%mean statistics(noprint) zu_cdeg_vio 4001 8000 compute zucc_vio(k)=%nobs compute zuct_deg_vio(k)=%mean statistics(noprint) cdeg_vio 4001 8000 compute cc_vio(k)=%nobs compute ct_deg_vio(k)=%mean statistics(noprint) l_cdeg_vio 4001 8000 compute lcc_vio(k)=%nobs compute lct_deg_vio(k)=%mean statistics(noprint) u_cdeg_vio 4001 8000 compute ucc_vio(k)=%nobs compute uct_deg_vio(k)=%mean compute ccoff0(k)=vc,ccoff1(k)=va, ccoff2(k)=vb compute cband5(k)=s_cband5,cband95(k)=s_cband95,cband1(k)=s_cband1,cband99(k)=s_cband99
set ce = u/sqrt(h)
compute s_cband99=ce(perc99)Code: Select all
compute s_cp99(tim1)=obser99Re: Value-at-Risk Forecasts with AR(1)-GARCH(1,1)
Thanks for clarification Tom.
How do I incorporate COEFFS series (there are available in the series window under COEFF(1), COEFFS(2), etc. labels) into mean and variance equations? I did simple "compute coeffs(3,4,5)=vc,va,vb", but as you can see the code generates an error in variance equation:
"## MAT13. Store into Out-of-Range Matrix or Series Element
The Error Occurred At Location 187, Line 12 of loop/block"
***VaR Forecasts
set ce = u/sqrt(h)
stats(fractiles) ce
compute s_cband1=-2.682658
compute s_cband5=-1.627572
compute s_cband95=1.538992
compute s_cband99=2.345644
set ht 1 1287 = 0.0
set ut 1 1287 = 0.0
do tim0=512,1287
compute tim1=tim0+1
compute ht(tim0)=h(tim0)
compute vc=coeffs(3)
compute va=coeffs(5)
compute vb=coeffs(4)
compute ht(tim1) = vc + va*ht(tim0) + vb*ut(tim0)**2
end do tim0
