Kilian 1998 (RES)
jonasdovern
Kilian 1998 (RES)
Post by jonasdovern »
Hallo,
I tried to replicate Kilian (1998), Small-Sample Conficence Intervals for Impulse Response Functions, RES (http://www.ssc.wisc.edu/~bhansen/718/Kilian1998.pdf). This is a procedure that takes a VAR model and computes confidence intervals for the IRFs based on the bootstrap after bootstrap approach explained in the paper (plus an auxiliary function):
function %%vecvecavg array
	type vec[rea] %%vecvecavg
	type vec[vec[rea]] array
	local integer n k i j
	local vec temp
	comp n = %rows(array)
	comp k = %rows(array(1))
	dim temp(n) %%vecvecavg(k)
	do i=1,k
		ewise temp(j) = array(j)(i)
		comp %%vecvecavg(i) = %avg(temp)
end function
procedure KILIAN98 start end
	type integer start end
	option model   model
	option integer ndraws 1000
	option integer niters 2000
	option real    signif .95
	option integer steps 8
	option switch  graph 0
	option switch  display 0
	local integer  nvar i j k draw time
	local vec[ser] origser resids udraws artifser upper lower median
	local rec[ser] girf impulses
	local vec      betaols bias betatilde betatildestar
	local vec[com] cv
	local ser[int] entries
	local vec[vec[rea]] betastar
	local vec[rec[ser]] bgirf
	local vec      work frac
	local real     maxupper minlower adjfactor
	local model    origmodel
	comp nvar = %modelsize(model)
	dim udraws(nvar) betastar(ndraws) bgirf(niters) upper(nvar) lower(nvar) median(nvar) girf(nvar,nvar)
	do draw=1,niters
		dim bgirf(draw)(nvar,nvar)
	* Save original data
	dim origser(nvar)
	do i=1,nvar
	   set origser(i) start end = ([series] %modeldepvars(model)(i))
	* Estimate model and save IRFs based on OLS estimates
	estimate(noprint,model=model,resid=resids) start end
	comp origmodel = model
	comp betaols = %BETASYS
	impulse(noprint,model=model,results=girf,steps=steps)
	infobox(action=define,progress,lower=1,upper=ndraws) "Estimating Bias"
	do draw = 1,ndraws
 		infobox(current=draw)
		* Restore original data and model
		do i=1,nvar
			set ([series] %modeldepvars(model)(i)) start end = origser(i)(t)
		comp %modelsetcoeffs(model,betaols)
		* Draw a bootstrapped sample
		boot entries start end start end
		do i=1,nvar
			set udraws(i) start end = resids(i)(entries(t))
		forecast(paths,model=model,from=start,to=end,nostatic,results=artifser,noprint)
		# udraws
		do i=1,nvar
			set ([series] %modeldepvars(model)(i)) start end = artifser(i)(t)
		* Estimate VAR based on resampled data
		estimate(noprint,model=model) start end
		comp betastar(draw) = %BETASYS
	end do draw
	infobox(action=remove)
	* Compute estimate of bias
	comp bias = %%vecvecavg(betastar)-betaols
	* Check stationarity and correct for bias
	eigen(cvalues=cv) %modelcompanion(model)
	if %cabs(cv(1))>=1.
		comp betatilde = betaols
	else {
		comp adjfactor=1., betatilde = betaols-adjfactor*bias
		comp %modelsetcoeffs(model,betatilde)
		while %cabs(cv(1))>=1. {
			comp betatilde = betaols-adjfactor*bias
			comp adjfactor=adjfactor-0.01
	* Using betatilde to perform the second bootstrap
	forecast(nopaths,model=model,from=start,to=end,nostatic,results=artifser,noprint)
	do i=1,nvar
		set resids(i) start end = origser(i)(t)-artifser(i)(t)
	dim betastar(niters)
	infobox(action=define,progress,lower=1,upper=niters) "Running Second Bootstrap"
	do draw = 1,niters
		* Restore original data and model (with betatilde)
		do i=1,nvar
		do i=1,nvar
		# udraws
		do i=1,nvar
		if %cabs(cv(1))>=1.
			comp betatildestar = betatilde
		else {
			comp adjfactor=1., betatildestar = betatilde-adjfactor*bias
			comp %modelsetcoeffs(model,betatildestar)
				comp betatildestar = betatilde-adjfactor*bias
		impulse(noprint,model=model,results=impulses,steps=steps)
		do i=1,nvar
			do j=1,nvar
				set bgirf(draw)(i,j) 1 steps = impulses(i,j)(t)
	end do draw
	do i=1,nvar
	* Compute fractiles of IRFs
	decl rect[ser] %UPPER(nvar,nvar) %LOWER(nvar,nvar)
	dim work(niters)
	do i=1,nvar
		do j=1,nvar
			do time=1,steps
				ewise work(k) = bgirf(k)(i,j)(time)
				comp frac=%fractiles(work,||(1-signif)/2.,.5,(1+signif)/2.||)
				set upper(j) time time = frac(3)
				set median(j) time time = frac(2)
				set lower(j) time time = frac(1)
			end do time
			set %UPPER(i,j) 1 steps = upper(j)(t)
			set %LOWER(i,j) 1 steps = lower(j)(t)
	* Plot results
	if graph {
		spgraph(hfi=nvar,vfi=nvar)
		do i=1,nvar
			comp minlower=maxupper=.0
			do j=1,nvar
				do time=1,steps
				end do time
				comp maxupper=%max(maxupper,%maxvalue(upper(j)))
				comp minlower=%min(minlower,%minvalue(lower(j)))
			do j=1,nvar
				graph(ticks,min=minlower,max=maxupper,number=0) 4 i j
				# girf(i,j) 1 steps;
				# median(j) 1 steps 3
				# upper(j) 1 steps 2
				# lower(j) 1 steps 2
	if display {
		disp; disp; disp   "    Variable                  OLS/IV   Bootstrap   Bias    "
		do i=1,nvar
			disp; disp %l(%eqndepvar(%modeleqn(model,i)))
			do j=1,%rows(%modelgetcoeffs(origmodel))
				disp j @+0 "." @5  %l(%eqntable(%modeleqn(model,i))(1,j)) @+0 "{" @+0  %eqntable(%modeleqn(model,i))(2,j) @+0 "}"	@30 "" $
				               @@.2  *.##### betaols((i-1)*%rows(%modelgetcoeffs(origmodel))+j)	$
				               @@.10 *.##### betatilde((i-1)*%rows(%modelgetcoeffs(origmodel))+j)	$
				               @@.10 *.##### bias((i-1)*%rows(%modelgetcoeffs(origmodel))+j)
		disp; disp "Number of replications for bias estimation:" *. ndraws
		disp "Number of replications for 2nd bootstrap:" *. niters
end procedure KILIAN98
The second file uses this procedure and replicates the MC-simulation shown in the paper for one specific parameterization of the DGP:
all 2000
comp B = .5
comp sigma = ||1, 0.3|0.3, 1||
comp F = %decomp(sigma)
decl ser[vec] u
gset u = %ranmvnormal(F)
set y1 1 1 = 0
set y2 1 1 = 0
do time=2,2000
	set y1 time time = B*y1{1}+u(time)(1)
	set y2 time time = 0.5*y1{1}+0.5*y2{1}+u(time)(2)
end do time
graph 2; # y1; # y2
* Set up true model and compute true IRFs
system(model=true)
	var y1 y2
	lags 1 to 1
estimate
comp %modelsetcoeffs(true,||B,.5|.0,.5|.0,.0||)
impulse(print,model=true,results=trueirf,steps=12)
source(echo) kilian98.src
@kilian98(model=true,ndraws=1000,steps=12,niters=1000,graph,display) 151 2000
* Do MC-Simulation
comp nruns=200
decl vec[rec[ser]] montiupper(nruns) montilower(nruns)
infobox(action=define,progress,lower=1,upper=200)
do run=1,nruns
	infobox(current=run)
	* Generate data
	set y1 1 1 = 0
	set y2 1 1 = 0
	do time=2,200
	end do time
	* Estimate model
	system(model=var)
		var y1 y2
		lags 1 to 1
	@kilian98(model=var,ndraws=500,steps=12,niters=500,nograph,nodisplay) 151 200
	dim montiupper(run)(2,2) montilower(run)(2,2)
	do i=1,2
		do j=1,2
			set montiupper(run)(i,j) 1 12 = %UPPER(i,j)(t)
			set montilower(run)(i,j) 1 12 = %LOWER(i,j)(t)
end do run
* Get coverage rates
decl rec[ser] coverage(2,2)
do i=1,2
	do j=1,2
		do step=1,8
			comp count=0
			do run=1,200
				if trueirf(i,j)(step)>=montilower(run)(i,j)(step).and.trueirf(i,j)(step)<=montiupper(run)(i,j)(step)
					comp count=count+1
			end do run
			set coverage(i,j) step step = count/200.*100
		end do step
graph(header="Coverages for coefficients of A") 4;
# coverage(1,1)
# coverage(1,2)
# coverage(2,1)
# coverage(2,2)
I suspect that there is some bug in the code because the intervals obtained by Kilian's method do almost never include the IRFs obtained from the true model. Thus, if anybody is also interested in this approach he/she might have a look at the code to try to find out whether there is something coded totally wrong or the strange results are just due to a syntax error that I overlooked.
marko3499
Re: Kilian 1998 (RES)
Post by marko3499 »
I would need to use this type of bootstrapping as well, and i was wondering if anyone has revised this code so that it works?
thanks in advance!
randal_verbrugge
Post by randal_verbrugge »
Tom Doan has come to the rescue.
https://estima.com/forum/viewtopic.php?f=8&t=2264
