iterative re-weighetd least squares method
tavera
Hi
has anyone already used the iteratively re-weighetd least squares method which seems to be an adequate robust method for estimating a Meta Regression model ?
I wonder if this can be implemented easily with winrats.
Many thanks in advance
Christophe Tavéra
Christophe Tavéra
Re: iterative re-weighetd least squares method
Is there a specific application that you had in mind?
tavera
Yes, I am working on the paper "Rose effect and the euro : is the magic gone ?", T. Havranek, Review of World Economics, 146(2): 2010, 241-261.
On page 247, the author suggests estimating the equation (3) of the paper with an iterative re-weighetd least squares method.
I don't really understand what is this procedure.
Chistophe Tavera
Chistophe Tavera
The standard RATS example ROBUST.RPF includes iterated weighted least squares for robust estimation, although, since RATS includes LAD directly through RREG, I would probably use that instead. (IWLS is often used to approximate LAD since it can be done with standard regressions, while LAD requires a specialized linear programming calculation).
tavera
many thanks Tom
Christophe Tavéra
Christophe Tavéra
