TVAR model
Scalper
TVAR model
Post by Scalper »
I am estimating a TVAR model for my PHd Thesis, but i have some doubts, mainly, in apply the commands in RATS. I´ve never used it before.
Firstly, how can i know which variable is the threshold variable?! Through a Test Tsay?
Secondly, for the calculating of threshold Value, we use which method : Tsay Test or Hansen test or both?!
Then we know that, is it possible to do the Granger Causality for each Regime?
Yours Sincerely,
Joaquim Ferreira
Re: TVAR model
The Tsay JASA 1998 examples are the best source for that, although the published results were wrong.
Given the threshold, you can run Granger causality tests on each branch since, conditional on the threshold, you can just do OLS estimation of the VAR equations.
Scalper
Re: TVAR model
Post by Scalper »
thank you TomDoan. But I though that the TSAY test it was only to determinate the delay paremeter.
how can i determinate the threshold Variable=??
Therefore, i can´t import my xls files to RATS and run the codes either. I dont know why. could you help me?
Thank you very much
yours sincerely,
Re: TVAR model
Scalper wrote:thank you TomDoan. But I though that the TSAY test it was only to determinate the delay paremeter.
The largest LM test combination of delay and threshold variable would be the best choice.
Scalper wrote:Therefore, i can´t import my xls files to RATS and run the codes either. I dont know why. could you help me?
If you're having trouble reading your data set, you should contact support@estima.com.
