Multivariate MS GARCH
DanielKing
Post by DanielKing »
I am trying to develop a CCC bivariate version of Gray's(1996) MS-GARCH with single-regime mean equations for stock returns. I think the general logic of my code is fine, it draws heavily on the Gray(1996) paper replication example. For some reason however, the following error message pops up during the maximisation (the final line of code):
The Error Occurred At Location 196, Line 19 of %MSPROB
I have tried to change the estimation range, but this does not help so far.
The code is as below.
Any help on the possible causes of this error message would be appreciated.
Daniel King
OPEN DATA "C:\Users\daniel\Desktop\MSCIDaily.xlsx"
CALENDAR(D) 2002:6:3
DATA(FORMAT=XLSX,ORG=COLUMNS,SHEET="Returns") 2002:06:03 2011:12:30 Nigeria SA Kenya Egypt
*Standardise series names for easy changes
set y = sa
set x = egypt
@MSSetup(states=4)
linreg(robust) y
# constant y{1}
*Store initial parameter values for y
compute olsvar1 = %seesq
compute coeff11 = %beta(1)
compute coeff12 = %beta(2)
linreg(robust) x
# constant x{1}
*Store  initial parameter values for x
compute olsvar2 = %seesq
compute coeff21 = %beta(1)
compute coeff22 = %beta(2)
* Get some initial values for the MV-GARCH process
garch(p=1,q=1,mv=cc)	/y x
*Declare all variables and assign initial values
* b(coefficient no.,series) - mean equations;
*a(coefficient no., regime, series) and rho – variance equations
nonlin b0y b1y b0x b1x a01y a02y a11y a12y a21y a22y a01x a02x a11x a12x a21x a22x rho1 rho2 p
compute b0y=coeff11, b1y=coeff12, b0x=coeff21, b1x=coeff22
compute a01y=%beta(3),a02y=3*%beta(3), a11y=%beta(5), a12y=3*%beta(5), a21y=%beta(7), a22y=3*%beta(7)
compute a01x=%beta(4), a02x=3*%beta(4), a11x=%beta(6), a12x=3*%beta(6), a21x=%beta(8), a22x=3*%beta(8)
compute rho1=0.5*%beta(9), rho2=2*%beta(9)
compute p=||.8,.1,.0,.0|.1,.8,.1,.1|.1,.1,.8,.1||
*Assign initial values to squared residuals and conditional variances
set uu1 = olsvar1
set uu2 = olsvar2
set h1 = olsvar1
set h2 = olsvar2
function RegimeGARCHF t
type vector RegimeGARCHF
type integer t
local real h11 h21 cov1 h12 h22 cov2 muy mux
local rectangular HH1(2,2) HH2(2,2) HH3(2,2) HH4(2,2)
local vector U
*Define variance-covariance equations for each series, each regime
compute h11= a01y+a11y*uu1(t-1)+a21y*h1(t-1)
compute h12 = a02y+a12y*uu1(t-1)+a22y*h1(t-1)
compute h21 = a01x+a11x*uu2(t-1)+a21x*h2(t-1)
compute h22 = a02x+a12x*uu2(t-1)+a22x*h2(t-1)
compute cov1 = rho1*sqrt(h11)*sqrt(h21)
compute cov2 = rho1*sqrt(h11)*sqrt(h22)
compute cov3 =rho2*sqrt(h12)*sqrt(h21)
compute cov4 =rho2*sqrt(h12)*sqrt(h22)
*Define mean equations for each series
compute muy=b0y+b1y*y(t-1)
compute mux=b0x+b1x*x(t-1)
*Fill covariance matrices
compute HH1 = ||h11, cov1|cov1,h21||
compute HH2 = ||h11, cov2|cov2,h22||
compute HH3 = ||h12, cov3|cov3,h21||
compute HH4 = ||h12, cov4|cov4,h22||
*Fill residuals vector
compute U = ||y(t)-muy,x(t)-mux||
*Fill vector of raw density functions
compute RegimeGARCHF=||exp(%logdensity(HH1,U)), exp(%logdensity(HH2,U)), exp(%logdensity(HH3,U)), exp(%logdensity(HH4,U))||
*Update variable values
compute uu1(t)= (y(t)-muy)^2
compute uu2(t)= (x(t)-mux)^2
compute h1(t)=(pstar(1)+pstar(2))*(muy^2+h11)+(pstar(3)+pstar(4))*(muy^2+h12)-muy^2
compute h2(t)=(pstar(1)+pstar(3))*(mux^2+h21)+(pstar(2)+pstar(4))*(mux^2+h22)-mux^2
frml logl = f=RegimeGARCHF(t),fpt=%MSProb(t,f),log(fpt)
maximize(start=(pstar=%MSInit()),method=bfgs,iters=100) logl %regstart() %regend()
moderator
Site Admin
Re: Multivariate MS GARCH
Post by moderator »
Daniel,
Can you post the data file, or email it to support@estima.com? That would make debugging this easier.
Tom Maycock
Estima
DanielKing
Apparently the file is too big to be posted, so I will e-mail it.
Thank you for your help.
Daniel King
moderator
Site Admin
Post by moderator »
Email sent. Looks like the issue was a missing @MSFilterInit call, and an issue with the start period on MAXIMIZE.
Tom Maycock
Estima
DanielKing wrote:I am trying to develop a CCC bivariate version of Gray's(1996) MS-GARCH with single-regime mean equations for stock returns. I think the general logic of my code is fine, it draws heavily on the Gray(1996) paper replication example.
I'm not a fan of Gray's procedure/model. It uses a fairly crude approximation and is too loosely parameterized to give good results. (It's too easy to get both branches being unstable GARCH models). The Dueker approach seems to work better, both because it has a more accurate approximation (waiting longer to collapse the states) and also because it is more tightly parameterized.
DanielKing
Thanks for the advice, I will definitely look into it.
In my attempt to build an equivalent Multivariate version of Hamilton and Susmel's SWARCH (as in Ramchand and Susmel, 1998; Edwards and Susmel, 2001, 2003), I have written the code below. However, early on in the maximisation it gives the error message "## SR10. Missing Values And/Or SMPL Options Leave No Usable Data Points".
I have changed the estimation range and initial values but cannot see any obvious reason why these are a problem. I am using the same data as above.
Any help is appreciated greatly,
Daniel King
set y = sa
set x = nigeria
@MSSetup(lags=1,states=4)
dec rectangular Z
dec vect gvy(2)
dec vect gvx(2)
dec real a1y a1x
dec vect rho(2)
dec real alphay betay alphax betax
nonlin(parmset=meanparms) alphay betay alphax betax
nonlin(parmset=archparms) a1y gvy a1x gvx rho
nonlin(parmset=msparms)   theta
compute Z=%zeros(2,2)
clear uuy uy uux ux
function ARCHRegime time ey ex
type vector ARCHRegime
type real ey ex
type integer time
local vector U
local integer 	i
local real hy hx vary varx cov
dim ARCHRegime(nexpand)
do i=1, nexpand
if %MSLagstate(i,1)==1{
compute hy=1+a1y*uuy(time-1)/gvy(1)
compute hx=1+a1x*uux(time-1)/gvx(1)
compute cov=rho(1)*sqrt(hy)*sqrt(hx)}$
else if %MSLagState(i,1)==2{
compute hx=1+a1x*uux(time-1)/gvx(2)
else if %MSLagState(i,1)==3{
compute hy=1+a1y*uuy(time-1)/gvy(2)
compute cov=rho(2)*sqrt(hy)*sqrt(hx)}$
else {
end if
if %MSLagstate(i,0)==1{
compute vary=hy*gvy(1)
compute varx=hx*gvx(1)}$
else if %MSLagState(i,0)==2{
compute varx=hx*gvx(2)}$
else if %MSLagState(i,0)==3{
compute vary=hy*gvy(2)
else {
end if
compute HH=||vary, cov|cov,varx||
compute U=||ey,ex||
*Check that variance terms are positive
if HH(1,1)>Z(1,1){if HH(2,2)>Z(2,2){ARCHRegime(i)= exp(%logdensity(HH,U)}else{ ARCHRegime(i)=0.0}}else{ ARCHRegime(i)=0.0}
end if
linreg y
# constant y{1}
compute alphay=%beta(1),betay=%beta(2)
compute gvy=%seesq*||0.2,5.0||
compute a1y=0.05
set uuy = %seesq
set uy  = %resids
frml ufy = y-alphay-betay*y{1}
linreg x
# constant x{1}
compute alphax=%beta(1),betax=%beta(2)
compute gvx=%seesq*||0.2,5.0||
compute a1x=0.05
set uux = %seesq
set ux  = %resids
frml ufxx = x-alphax-betax*x{1}
compute rho=||0.1,0.5||
compute p = ||0.8,0.2,0.1,0.0|0.1,0.6,0.2,0.0|0.1,0.1,0.6,0.2||
compute theta=%msplogistic(p)
compute gstart=%regstart()+1,gend=%regend()
frml logl = uy(t)=ufy(t),uuy(t)=uy(t)^2, ux(t)=ufxx(t), uux(t)=ux(t)^2, f=ARCHRegime(t,uy(t), ux(t)), fpt=%MSProb(t,f),log(fpt)
@MSFilterInit
maximize(parmset=meanparms+archparms+msparms,$
  start=%(p=%mslogisticp(theta),pstar=%MSInit()),$
 method=bfgs,iters=400,pmethod=simplex,piters=5) logl gstart gend
I'm not 100% sure how RATS was interpreting the tangle of {..}'s at the end of your ARCHRegime function, but the following seems to work better:
if HH(1,1)>Z(1,1) {
if HH(2,2)>Z(2,2) {
compute ARCHRegime(i)= exp(%logdensity(HH,U))
else {
compute ARCHRegime(i)=0.0
else {
though actually that can be simplified still further to
compute ARCHRegime(i)=%if(HH(1,1)>Z(1,1).and.HH(2,2)>Z(2,2),exp(%logdensity(HH,U)),0.0)
DanielKing
Thanks very much, the latter if statement does sort out that problem.
However, a new problem has arisen. The maximisation runs as normal for a few minutes, followed by the error message: "## MAT14 Non-invertible matrix. Using Generalised Inverse for Symmetric. The Error occorred at Location 170, Line 13 of %MSINIT", a few hundred times. This is then followed by results in which all the transition probabilities are all highly insignificant.
I have checked that the p matrix is invertible and have experimented with different initial values, but this does not help so far.
Thank you for all the help.
Daniel King
Your covariance is computed wrong - you're applying the correlation to the "deflated" variances, not to the ones that are reflated by the GV values. The following simplifies and corrects your ARCHRegime function. You also might want to play with your guess values for P a bit. States 1 and 4 aren't as "distant" from each other as they might be if this were an ordered 4 regime model so forcing guesses of 0 probabilities for transitions isn't a good idea.
type real ey ex
type integer time
local vector U
local integer    i
local integer xstate ystate
do i=1,nexpand
   * Do calculations based upon lagged regime
   compute xstate=1+(%MSLagState(i,1)==2.or.%MSLagState(i,1)==4)
   compute ystate=1+(%MSLagState(i,1)==3.or.%MSLagState(i,1)==4)
   compute hy=1+a1y*uuy(time-1)/gvy(ystate)
   compute hx=1+a1x*uux(time-1)/gvx(xstate)
   * Do calculations based upon current regime
   compute xstate=1+(%MSLagState(i,0)==2.or.%MSLagState(i,0)==4)
   compute ystate=1+(%MSLagState(i,0)==3.or.%MSLagState(i,0)==4)
   compute vary=hy*gvy(ystate)
   compute varx=hx*gvx(xstate)
   compute cov=rho(ystate)*sqrt(vary)*sqrt(varx)
   compute U=||ey,ex||
DanielKing
Thanks very much for all the help - especially regarding the more elegant characterisation of states. It seems that the model is producing sensible results in general.
For some data sets, the Non-invertible matrix error message arises for particular guess values of the p-matrix. It seems very sensitive to this. Mostly though, a little bit of tinkering leads to results.
Thanks again.
Daniel King
DanielKing wrote:Thanks very much for all the help - especially regarding the more elegant characterisation of states. It seems that the model is producing sensible results in general.
Thanks again.
Daniel King
The non-invertible matrix is actually just a warning, and should be occurring only on some of the early function evaluations. Could you post your finished product?
