Replication Examples for Pesaran, Shin, and Smith (2001)
nacrointfin
Could you give the Replication Examples forf Pesaran, M. H., Y. Shin, and R. J. Smith (2001), “Bounds Testing Approaches to the
Analysis of Level Relationships,” Journal of Applied Econometrics, 16, 289–326. File attached is the data file of the paper.
- pss-data.zip
- (22.26 KiB) Downloaded 1742 times
Re: Replication Examples for Pesaran, Shin, and Smith (2001)
Isn't the whole point that you run OLS regressions and compute F's and t's by standard methods? The only thing non-standard is the distribution of those F's and t's, not the method for calculating them.
nacrointfin
Yes, it is. An LS regression can do the job. What I am wondering is should the current values of differenced independent variables put in the bounds testing regression? In eq.(30) of Pesaran et al. (2001), the current values of differenced independent variables are in the regression equation. But in the manual of mircofit(see file attached, page 318, line 8 form the top ), it indicates the current values of differenced independent variables should be excluded in bounds testing and once the long run relation is verified those current values will be taken in account. Which one is correct? Or both are the same?
- ardl.pdf
- (163.59 KiB) Downloaded 1834 times
May I ask if anyone is aware of the availability of the program (i.e. codes) for Pesaran, Shin, and Smith (2001)? If it is publicly available, then could you please share the source where I may find the program?
