I estimated the FTP-MS model with @MSRegression you suggested previously, and it works!! (Thank you again for your kindly help
Now I want to estimate the TVTP-MS model rather than FTP-MS model.
It seems that @MSRegression can also estimate the TVTP-MS model according to the description you made at
http://www.estima.com/forum/viewtopic.p ... 1208#p4302.
I found one example demonstrating the estimations with @MSRegression, but the transition probabilities in this example vary only with means.
(example:http://www.estima.com/forum/viewtopic.p ... t=30#p5340)
cal(d) 2006:03:24
open data "one_sample_ap.xls"
data(format=xls,org=cols) 2006:03:24 2012:03:05 apexcess aprm aprmsq logvix
sample(smpl=%valid(apexcess)) apexcess / apexcess_nomissing
sample(smpl=%valid(aprm)) aprm / aprm_nomissing
sample(smpl=%valid(aprmsq)) aprmsq / aprmsq_nomissing
sample(smpl=%valid(logvix)) logvix / logvix_nomissing
calendar(irregular)
compute gstart=1,gend=%nobs
@msregression(states=2,switch=ch) apexcess_nomissing
# constant aprm_nomissing aprmsq_nomissing
@msreginitial gstart gend
@MSFilterSetup(em)
nonlin(parmset=common) betas sigsqv
dec equation p1eq p2eq
dec vector v1 v2
dec vector p1mean p2mean
nonlin(parmset=tv) v1 v2
* Define the logistic index for the transitions
equation p1eq *
# constant
equation p2eq *
# constant
dim p1mean(1) p2mean(1)
compute p1mean(1)=1.0,p2mean(1)=1.0
* Function to compute the transition probability matrix
function %MSPmat time
type rect %MSPmat
type int time
local integer i j
local rect pexpand
local real z
local rect p
dim p(1,2)
compute %MSInitTransition()
if nexpand==nstates {
compute %MSPmat=pexpand*p
ewise %MSPmat(i,j)=%if(i==nstates,1.0+%MSPmat(i,j),%MSPmat(i,j))
else {
dim %MSPmat(nexpand,nexpand)
ewise %MSPmat(i,j)=MSTransProbs(MSTransLookup(i,j))
* Initialize the probabilities using only the means
function TVPInit
type vector TVPInit
local rect a
local integer i j
dim p(1,2)
compute p(1,1)=%(z=exp(%dot(p1mean,v1)),z/(1+z))
compute p(1,2)=%(z=exp(%dot(p2mean,v2)),1/(1+z))
compute TVPInit=%MSInit()
compute p=%MSPExpand(p)
procedure MSTVPEMEstimate start end
type integer start end
option integer iters 100
option real cvcrit 1.e-6
local integer emits time k
local series l11 l22 w11 w22
local vector baseparms testparms
local rect thisEntry
dim thisEntry(nstates,nstates)
compute baseparms=v1~~v2
do emits=1,iters
compute %eqnsetcoeffs(p1eq,v1)
compute %eqnsetcoeffs(p2eq,v2)
compute TVPInit()
@MSRegestep start end
compute %emlogl=%logl
@MSRegmstep(nodop,nodobeta,dosigma) start end
set l11 start end = 0.0
set l22 start end = 0.0
set w11 start end = 0.0
set w22 start end = 0.0
compute tvemlogl=0.0
do time=start,end
compute p=%MSPMat(time)
compute thisEntry=%zeros(nstates,nstates)
do k=1,MSEMSize
compute thisEntry(MSEMLagRegime(k,1),MSEMLagRegime(k,2))+=MSEMpt_sm(time)(k)
compute tvemlogl+=log(p(MSEMLagRegime(k,1),MSEMLagRegime(k,2)))*MSEMpt_sm(time)(k)
end do k
compute w11(time)=p(1,1)*(1-p(1,1))*(thisEntry(1,1)+thisEntry(2,1))
compute w22(time)=p(1,2)*(1-p(1,2))*(thisEntry(2,2)+thisEntry(1,2))
compute l11(time)=(thisEntry(1,1)- p(1,1)*(thisEntry(1,1)+thisEntry(2,1)))/w11(time)
compute l22(time)=(thisEntry(2,2)-(1-p(1,2))*(thisEntry(2,2)+thisEntry(1,2)))/w22(time)
end do time
* Update the coefficients
linreg(noprint,weight=w11,equation=p1eq) l11 start end
compute v1=v1+%beta
linreg(noprint,weight=w22,equation=p2eq) l22 start end
compute v2=v2+%beta
do time=start,end
do k=1,MSEMSize
end do k
end do time
* Check for convergence
compute testparms=v1~~v2
compute %cvcrit=%testdiff(baseparms,testparms)
if %cvcrit<cvcrit
break
compute baseparms=testparms
disp "Iteration" emits "Log Likelihood" %emlogl %cvcrit
end do emits
end MSTVPEMEstimate
compute v1=log(.7/.3)
compute v2=log(.95/.05)
@MSTVPEMEstimate(cvcrit=.0001) gstart gend
equation p1eq *
# constant logvix{1}
equation p2eq *
dim p1mean(%eqnsize(p1eq)) p2mean(%eqnsize(p2eq))
do i=1,%eqnsize(p1eq)
sstats(mean) gstart gend %eqnxvector(p1eq,t)(i)>>p1mean(i)
do i=1,%eqnsize(p2eq)
sstats(mean) gstart gend %eqnxvector(p2eq,t)(i)>>p2mean(i)
compute v1=v1~~0.0
compute v2=v2~~0.0
@MSTVPEMEstimate(cvcrit=.0001,iters=50) gstart gend
* Polish estimates using BHHH
frml logltvtp = p=%MSPMat(t),log(%MSRegProb(t))
@MSFilterInit
maximize(parmset=tv+common,start=(pstar=TVPInit()),method=bhhh,iters=10) logltvtp gstart gend(That is, how to modify the code of the example to make the transition probabilities vary with some exogenous variables? )
Best regards,
Samson
